Water Pump Help Please
Water Pump Help Please was created by deepfat
Posted 2 years 6 months ago #199033
Got it timed and belt off just the water pump to come off I've undone and removed the 5 bolts but it appears to be stuck where indicated in the photo, this hole on the new pump is threaded. Have I missed something I thought this hole was for a locating pin so why is it threaded? another model perhaps. Thought I should ask before getting heavy handed and forcing it.
The bottom right mounting point on the new pump is also different and has what I believe is an evaporation chamber and I can understand what this is meant to do, what I can't understand is why does the mounting bolt have another 8mm bolt screwed in the end which in my case was literally finger tight it appears to do nothing.
Attachment not found
by deepfat
Replied by minimax on topic Water Pump Help Please
Posted 2 years 6 months ago #199037
There is a bolt that goes through it from behind.
by minimax
