4 pot caliper bolts, what size?
4 pot caliper bolts, what size? was created by VVCJames
Posted 2 years 5 months ago #199405
Hi all,
Ive decided to treat my F to some 4 pot calipers and multispoke 160 wheels. My old brakes are getting due and overhaul, and an luck would have it a friend was breaking a very crispy 160 TF.
Sadly... due to the crispy nature, one of the bolts snapped off during removal, ive drilled it out, however nicked the hellicoil with the drill :doh: So, am looking at re coiling it, however, i cant get a nice read on what size i need. (i know there is not guarantee it is the standard size)
What size should the thread and bolt be on these ap racing 4 pots to attach to the hub? (and im guessing they don't normally come with coils in them :pinch: )
Thanks, James
Replied by trevtherev on topic 4 pot caliper bolts, what size?
Posted 2 years 5 months ago #199414
Just saw your post, will have a look tomorrow and see what size the threads are. I noticed the set I've just bought had been helli coiled, so maybe someone else can say if it is normal.
Posted 2 years 5 months ago #199417
Having just had a look, I see both my calipers have helli coils, so I take it that's normal, or the previous owner had been a bit OTT with the sockets.
The size bolts I have are 12 mm x 35 mm x 1.75 pitch flange head bolts. The rating I have is 10.9 Although I believe the normal rating is 8.8
The following user(s) said Thank You: VVCJames
Replied by VVCJames on topic 4 pot caliper bolts, what size?
Posted 2 years 4 months ago #199419
Thanks :) will get a new coil ordered, interesting about the helicoils on yours too....
Posted 2 years 4 months ago #199424
I can only assume that the caliper casting are of an aluminium construction and the coil inserts give a much stronger thread form.
Time to create page: 0.645 seconds
