MGTF Suspension
Hi there,
this query relates to MGTF coil over units and in particular the bottom bushes.
I removed both my rear ones for a refurb and to locate a creak in the rear o/s.
The units are very easy to strip down ( don't need coil compressors) in case anyone is interested.
What I found is that the bottom bushes behave differently. That is one is easy to move by finger pressure and the other completely stiff.
Does anyone know what a good /new bottom suspension bush should feel like when it is fitted to the damper ?
thanks
Mike
thanks
Mike
by g4wam
- BruceTF135
On the TF, is the bottom bush on the suspension units even replaceable? I was told that they aren't and had to buy new suspension units complete. The bushes had gone soft enough that, with a pry bar, the bottom bush moved on the bolt.
by BruceTF135
- trevtherev
- Journeyman MGer
Yes I had both my suspension bottom bushes replaced last Aug when I rebuilt them along with a general overall of both sub frames
by trevtherev
- BruceTF135
Out of interest, for when I need to do the fronts, where did you get the bushes? Do you have a link, please?
by BruceTF135
- trevtherev
- Journeyman MGer
I got my replacement bottom bushes from mgfntfbitz
MGFnTFBITZ .. Unit 13 Dinting Lane Industrial Estate. Glossop. Derbyshire. SK13 7NU Tel 01457 238202 / Mobile 07854 547722
They also sell on ebay
by trevtherev
Needing you bottom bushes replaced sounds most discomforting…. I hope you get well soon! :bust: :bust:I got my replacement bottom bushes from mgfntfbitz
thanks for your reply
it transpires that the bottom bushes on TF dampers are like knuckle joints, they should move freely in all directions and stay in position like a track rod end does.
Mike
Mike
by g4wam
- trevtherev
- Journeyman MGer
Its from sitting on wet ground so I was told
by trevtherev
Time to create page: 0.536 seconds
