Driver's door lock - Interior lamps not working
Driver's door lock - Interior lamps not working was created by LanderMG
Posted 2 years 3 months ago #199568
Hello,
Thanks for providing so much help in the past, but now got another issue....
I'm sure it's a common problem but thought I'd ask.
When locking the F, I have found the indicators don't flash, but the doors do lock when using the remote,and the LED stays lit. However, when I use the key, the doors lock and then unlock straight away.
Something I have noticed is when I look at the catch on the door, the catch doesn't rotate all the way. Using a screw driver to push the catch round till as far as it goes will illuminate the interior lights. Then when I use the remote to lock the door, the indicators flash, the doors lock and the LED flashes.
If I then lift the door handle and roll the catch anti clockwise as if opening the door, the alarm does go off.
So it seems that the issue appears that when I close the door, the catch isn't rotating clockwise enough.
Anybody seen that issue?
Thanks in advance.
Thanks in advance.
by LanderMG
Replied by talkingcars on topic Driver's door lock - Interior lamps not working
Posted 2 years 3 months ago #199574
Lithium spray grease in the barrel works wonders.
Don't use WD40. It dries out and goes sticky allowing dust to pulled up.
by talkingcars
Time to create page: 0.510 seconds
