management light on took to local garage
It came up with several codes p0481,p0118 p0553 and po170 he thinks its the coolant temp sensor but the temp gauge is reading normal a y suggestions
by Newbe
Replied by SteveFMk1 on topic management light on took to local garage
Posted 2 years 3 months ago #199766
Sorry missed the heading.
Can i ask what the problem was? 2 codes are temp related, 1 is power steering and the other fuel. These might be old codes logged on the ecu, why not just have them cleared, run the car for a couple of weeks and check the codes again.
Last Edit:2 years 3 months ago
by SteveFMk1
Last edit: 2 years 3 months ago by SteveFMk1.
Replied by Newbe on topic management light on took to local garage
Posted 2 years 3 months ago #199767
Thanks for the prompt reply we only had it 4 weeks and I just have just replaced the cambelt. There are several other little jobs to sort but the car is running fine coolant temperature is about halfway. I did unplug the coolant fans sensor to check they are both working which they are. A few days ago the engine management light came on but the car is running fine. The garage seems to think its the coolant sensor but the gauge is reading normal I'm wondering if it's the coolant fan sensor. They have cleared the error codes so I think like you suggested I will run it and see how it goes
by Newbe
Replied by Cobber on topic management light on took to local garage
Posted 2 years 3 months ago #199770
There is more than one temp sensor, there is one for the gauge and a seperate one for the ecu.
It may well be that the temp sensor for the ecu is buggered, or the plugs on the two sensors have been put on arse about.
Gauges aren’t very accurate, in order to be accurate they would need their calibration checked regularly ( Not a practical proposition ) a gauge is best used as a comparator, the actual numerical reading in itself at any given time is relatively meaningless, it’s various readings over a period of time that show a trend away from normal is their true value in diagnosis.
Once you get used to the range where a gauge needle normally sits, it’s when the needle sits somewhere other than normal that you worry
The following user(s) said Thank You: Newbe
Replied by talkingcars on topic management light on took to local garage
Posted 2 years 3 months ago #199772
As above, there are two coolant temp sensors, the one for the ECU is the one with two pins, the one for the dash has one pin.
There are two values for the two pin sensor depending on the engine management system. They used to be easy to tell apart as they were different colours but after market suppliers make them in any colour.
To check the two pin sensor plug an OBD reader in and see what temperature, if any,
To test the one pin sensor unplug it and earth the lead, the gauge should go to the top.
I disagree with Cobber - the dash gauge is good. The needle starts to move when the coolant is at 60'. When it reaches operating temp at 88' the needle will sit just below half way and remain there all the way up to 110'.
by talkingcars
Posted 2 years 3 months ago #199778
Another really helpful reply thank you very much. Hopefully I can now sorted it many thanks for all the replies.
by Newbe
Time to create page: 0.496 seconds
