Easy suspension bits
Hi ,
I am taking my tf off the road to do the coolant pipes. Whilst it's up I am thinking of changing other bits.
Are there any front or rear suspension components that can be changed without the need for a alignment?
L.
L.
by Shedifice
Why? Are you changing bits because you can although they are still good? That is a waste of time and money. Are you trying to avoid realigning the suspension even though parts may be worn out? That doesn't make sense either. Why not spend £20 making some alignment tools and get the suspension set up nicely instead?
by minimax
Ideally I want to completely refresh the underside but not at the stage of pulling the subframes. I have done a number of bits that needed doing already. One thing I want to do next year is the rear trailing arms as they are very rusted (safe, just adjustment is a pain) but that will need a complete realignment.
I was just after anything else I could refresh without the need to realign. I have done brakes and hoses, front drop links.
Prolly a stupid question, it was late (sober) ignore me
by Shedifice
Time to create page: 0.466 seconds
