Re:Back window
Hey my MG F 2000 back window is really foggy and unusable. What’s best thing to use to polish it out? It’s not cracked or torn
by Charlie1
Try some Renovo plastic window cleaner or similar.
by SteveFMk1
The following user(s) said Thank You: Charlie1
There is a product called greygate for exactly this use, or you can use Brasso or any clay based abrasive even T cut but beware of putting too much pressure on the plastic screen as its most likely the stitches will give way not the plastic.
by Steve
Thank you is Renzo a clay based one do you know? and can the window be unzipped and taken out when cleaning? I got inherited the car from a family member so still learning about the car so appeciate any help.
by Charlie1
Not sure about Renzo but the screen can be unzipped anand laid flat but not removed unless you drill out the rivets and replace, probably overkill.
by Steve
- BruceTF135
Unzip the window and lay it on something flat. You'll need to do it inside and outside. I used Meguiars PlastRX and lots of elbow grease but Greygates has been highly recommended many times. Easy job, just requires some effort.
This is my result:
This is my result:
by BruceTF135
