Passenger side window not working, no supply to switch
Passenger side window not working, no supply to switch was created by Borgy
Posted 1 year 7 months ago #201649
My sons car is now all up and running, and is MOT'd and on the road.
Just a couple of small issues left to deal with
Passenger side window not working. No supply to the switch. I thought it would be a fuse or a corroded fuse but checked, cleaned and cleaned the female connection on fuseboard.
Does the supply loop into anything before getting to the switch? Or am a looking for a broken wire?
02 plate 135 sprint
02 plate 135 sprint
by Borgy
Replied by Roverlike on topic Passenger side window not working, no supply to switch
Posted 1 year 7 months ago #201651
Check if you have power on the fuse number 5 under steering wheel. If not check if you have,power on the fuse nunber 4. If not then it would be relay that needs changing.
by Roverlike
Replied by Borgy on topic Passenger side window not working, no supply to switch
Posted 1 year 7 months ago #201653
Fuse 4 is fine as it feeds the drivers window , and that working, forgot to actually check id there is supply to the fuse way as I assumed it would be fed dioecy from a busbar on the fuse board. I will check
by Borgy
Time to create page: 0.504 seconds
