MG F KEY FOB
As Ive mentioned a few times ,I have alarm problems on my MG F Ive just had a mobile diagnostic man come and look a the car The problem is,the alarm is on and since the key fob isnt working he cant switch the alarm off . Since it is in this state ,he said he is unable to disable the alarm so Im in an awkward situation If I could find a key fob ,even long enough to switch the alarm off it may help Len
by digcot65
Sorry I forgot to add,someone mentioned a firm who can reprogram your ECU does anyone have the name of this company Len
by digcot65
https://www.google.co.uk/url?sa=t&source=web&rct=j&url=http://www.technozen-electronics.co.uk/&ved=2ahUKEwiextfi-rj-AhUPiFwKHR_EAAEQ_Bd6BAgSEAY&usg=AOvVaw2TOKFRys9XjVeNxwsZDXZu
This guy will help, he can provide new programmed fobs if you send him the ecu, he will also read the EKA code for you.
by Steve
At last I seem to be getting somewhere ,thanks to members help cant wait,to actually drive the MG Len
by digcot65
I have been in contact with Technozen and it looks promising .I did ask if it was possible,to permanently disable the alarm but they wern`t keen,saying it would require extra wiring,which member havealso said this .However several members have said its a case of removing the wire from pin 13 of the ECU only,when the alarm is not on .Other members have said that doing this ,the engine would still not work ,while someone said a 12volt supply via the ignition switch as to be connected to the ECU .Has any member actually permanently disabled their alarm system on their car,or is it just what they have heard .Knowing problems the alarm can cause,even if and when I get it sorted Id like it disabled .Technozen say in their write up ,the ECU can be programmed so the key fob is no longer required ,How does the alarm then be switched off .One day Ill get to drive the MG but I think Im getting nearer Len
by digcot65
Paul Brown at Technozen recommends I have the key fobs repaired and matched to the ECU he doesn`t believe its best to have alarm disabled. He said once he`s finished the system will be 100 % which is allI require .Ill let members know when I have the ECU back and fitted Len
by digcot65
Hello Len
I have a terrible fear of my imobilizer operation as having brought my MG F as a barn find and it cost me more than the car to get around the issue of not having the imobalizer fob. I eventually found a wizard that was able to get around it but he is in Australia.
I have seen this kit online (from WA in Autstalia) and will probably go down this path as car theft issues have been ameleoriated by evolution here in Australia. Most car thieves here are adolesent and usually only steal top of the range new cars and would think a manual car is a book.
-WA imobaliser Imobaliser kit.
https://www.immobiliserparts.com.au/MGF-IMMOBILISER-BYPASS-KIT-p/mgf-immobiliser-bypass.htm
-UK company that might have a solution for you.
Remobilise Ltd
42 Rhosnewydd
Tumble
Llanelli
SA14 6LA
United Kingdom
Tel: 01269 843068
Mob: 0787 142 4445
[email protected]
http://www.remobilise.co.uk
http://stores.ebay.co.uk/remobilise-ltd
Remobilise Ltd
42 Rhosnewydd
Tumble
Llanelli
SA14 6LA
United Kingdom
Tel: 01269 843068
Mob: 0787 142 4445
[email protected]
by cooperdm
Because of immobiliser systems, car thieves around here ( Melbourne ) now either car jack or break into your house to steal the keys,
So now not only is the immobiliser virtually pointless, it’s only made the situation worse and more dangerous.
Instead of just pinching your car, there is the possibility of them injuring you in the process of car jacking or of knocking off all your other stuff when they break in.
Worse still is if the nasty little, junkie, vermin, scrotes are breaking in whilst your home, then they can injure you whilst stealing your stuff.
That’s what I call progress!
hELLO i WAS ADVISED ,TO SEND MY ALARM UNIT AND KEY FOBS TO technozen to be matched up I spoke to Paul Brown at Technozen and he guarantees that once he has set them it will be 100% He also said ,there is no point in disabling the alarm,if its then working correctly Im waiting for mine to be returned and then to fit it Ill keep the Forum posted Len
by digcot65
Sorry hit the capitals key incorrectly
by digcot65
- sworkscooper
I have used Paul Brown ( Technozen) twice and I cannot recommend him highly enough. Once you have him sort the fobs and immobiliser you will be fine . In Paul we trust .
by sworkscooper
Time to create page: 0.654 seconds
