Interior clock issues
Interior clock issues was created by blacklake
Posted 5 months 3 weeks ago #207531
Well now that we have the seats and interior back in our 99 MGF, we discovered the clock doesn't work, which I understand is quite common!
However should it be permanently lit, and if not, do we we just take the bulb out? I'm just concerned it will drain the battery.
(Does look pretty in the dark though 😁)
Last Edit:5 months 3 weeks ago by blacklake
Last edit: 5 months 3 weeks ago by blacklake.
Replied by Cobber on topic Interior clock issues
Posted 5 months 3 weeks ago #207532
Whilst the clock itself should always be powered up, so as it can keep the time, the illumination should switch off with the lights.
Check the pin outs for the wiring for the clock, maybe the power feed to the clock has been switched with the power feed for the illumination of the clock that would explain the constant illumination of the clock and why it won't work....infact try seeing if the clock works when the lights are on!
Last Edit:5 months 3 weeks ago by Cobber
Last edit: 5 months 3 weeks ago by Cobber.
The following user(s) said Thank You: blacklake
Replied by blacklake on topic Interior clock issues
Posted 5 months 3 weeks ago #207533
You are right I think! (Just tried it in the cold and dark.) Oh well, the console is coming out again... that will make me popular.
Posted 5 months 3 weeks ago #207534
blacklake wrote: You are right I think! (Just tried it in the cold and dark.) Oh well, the console is coming out again... that will make me popular.
Glad to've been of help.......hopefully!
Time to create page: 0.545 seconds
