URGENT help with coolant pipes required MGF Trophy
URGENT help with coolant pipes required MGF Trophy was created by davidej
Posted 1 year 11 months ago #207799
HI all, looking for some urgent advice
MY Trophy was leaking coolant from one of the big hoses from the engine to the underfloor pipes. So I took them both off and bought replacements. I did take some photos before removing and I am now trying to install the new ones. It is a pre-PRT model
The photos don't seem to help much and I am now in a complete muddle which goes where. I have consulted several sources including the Roger Parker book and they all seem to give conflicting advice.
The only constant seems to be that the outlet for the coolant is the casting on the head and that should feed the drivers side pipe which goes to the top of the radiator. I am sure that the Y shaped pipe was attached there but the Roger Parker book says that the Y shape hose is the return pipe.
It si possible that the original one one the car were misplaced as they had obviously been off before I purchased it.
Can anyone please give me a definitive answer of which goes where. thanks in advance
by davidej
Replied by Pharg55 on topic URGENT help with coolant pipes required MGF Trophy
Posted 1 year 11 months ago #207807
Have a look at the EPC, link on the Home page of this website, it shows a good diagram of the pipes and hoses, I've just been using them myself to try to get things in the correct positions prior to refittinf them.
(Home, scroll to the bottom, and click on EPC.) Might give you some help.
by Pharg55
Replied by davidej on topic URGENT help with coolant pipes required MGF Trophy
Posted 1 year 11 months ago #207809
Thanks. I think that confirms what I have come to realise -ie that the hot coolant goes up the LHS of the underfloor pipes, not the RHS as I had previously assumed.
by davidej
Time to create page: 0.372 seconds
