Cost of engine rebuild...what should I do?
Replied by Pharg55 on topic Cost of engine rebuild...what should I do?
Posted 1 year 9 months ago #208917Please Log in or Create an account to join the conversation.
Replied by R40MGF on topic Cost of engine rebuild...what should I do?
Posted 1 year 9 months ago #208918Please Log in or Create an account to join the conversation.
Replied by c13amb on topic Cost of engine rebuild...what should I do?
Posted 1 year 9 months ago #208919I've had genuine cats fitted only a couple of years ago with every possible conceivable item thrown at it..lambda sensors repeatedly.. all cleaners to try and clear up the emissions. The head gasket isn't the issue here it's the fact that the head needs to come off to diagnose anything untoward and replaced so there's best part of £700 before anything else!!
I haven't got anywhere to store it at home until another recommended party is able to look at it as I know it can take months due to their popularity.
As the garage said they are happy to do the work and I'm happy to pay for it if I thought it was a viable option but the rest of the car is going to need some sort of restoration following on from this and there comes a point when you have to weigh up your options!
Posted 1 year 9 months ago #208922This is gutting but I need it gone before I really consider my next option!
Replied by Cobber on topic Cost of engine rebuild...what should I do?
Posted 1 year 9 months ago #208923Now the rust etc is entirely another matter and I can't help you with that part of the decision from afar.
But do you intend to replace the car with another MGF/TF? if so I'd hang on to this one and swap over any desirable/better/new bits over to it's replacement. before unloading the current car. Yes I realise space may be a problem but it is a short term problem, that requires you to find away how to swing it.
It's not how many problems or how big those problems are, but how you go about tackling them that defines you.
Posted 1 year 9 months ago #208926The rust is the problem as welding has been done for the last two MOTs so it's in the car now so the problem is do the engine work could be easy could be a right pain in the arse but then the car falls to bits in a couple more years and I'm finding it hard to justify the expense when the cars worth about £2k when fully fit!
I may be getting another MG possibly but not right away so the storage until I do may become a problem!
Posted 1 year 9 months ago #208927I doubt that every test possible has been used in diagnosis, Does the garage have a Pscan or a T4 Testbook? These are the OBD diagnotic tools dedicated to our cars, or is it just some generic OBD scanner, the effectiveness of these can vary wildly, even the good ones may not have to optional software package for our cars required to do anything more than the most basic stuff.
I realise that you lot have an entirely different perspective to distances than we do In Oz but here 25 miles is just a trip to the shops!
I'm not giving you a hard time, just for the devilment of it, but I am asking hard questions so that I may be better able to help you.
Â
Posted 1 year 9 months ago #208928Please Log in or Create an account to join the conversation.
Posted 1 year 9 months ago #208929"Keep calm, relax, focus on the problem & PULL THE BLOODY TRIGGER"
Replied by Airportable on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208932You can however travel to a test station for examination provided there has been prior arrangements made & the distance is commensurate with your location.
It would be nice to have a drive to Thurso, or possibly Bodmin, for an MOT but you might have to defend your actions in court if apprehended.
So although the powers that be seem to want to throw us back to the dark ages, with all the incivility that that entails, we can still take our cars for an MOT without up to date paperwork, providing prior arrangements have been made. And so Cobb’s we’re not (yet) as uncivilised as you intimate.
The fact that as you dutifully take your car for their test, you will most probably pass any number of cars without a ticket. This is life in Great Britain during the times we find ourselves in.
Replied by D4KGP on topic Cost of engine rebuild...what should I do?
Posted 1 year 8 months ago #208934Please Log in or Create an account to join the conversation.
Posted 1 year 8 months ago #208935In the less civilised states that demand an annual inspection so long as the rego is still current it is fine to drive the car to the RWC station and to a place of repair if needed in order to bring the car up to RWC standard, If the cars rego has lapsed or the car is unregistered you need to get a temporary permit from the rego authority (this can be done online) which allows you to only drive the car to various repairers as required, to also present the car for it's RWC inspection and the the rego office there is no limitation on how far but you must use the most direct route and you must not use any tollways, There is also a restriction on the time of day, it must be during daylight hours (probably in case the lights aren't working properly)
I'm fortunate to live in the state of Victoria which has no annual inspection requirement, a car only requires an inspection when it has no current rego (even then you have a 3 month grace period in which you cant use the car till you pay the renewal but you still don't need an inspection) or the car is either unregistered or you are transferring the ownership then you require a RWC (Road Worthy Certificate)
It's interesting to note that there is no appreciable difference in accident rates between the states that require annual inspections and those that don't require any such nonsense.
There is a constant running lobbying battle between the VACC (Victorian Automobile Chamber of Commerce. car dealers and repairers)Â and the very connected and very politically powerful RACV (Royal Automobile Club of Victoria)Â The VACC wants annual inspections (No vested interest there....not many!) and the RACV won't have a bar of it.
Disclosure note: I did used to work as a contractor for the RACV and was a member of the VACC, so as a result got to watch the antics from within both sides up close.
