Fuel delivery Problem
Replied by Cobber on topic Fuel delivery Problem
Posted 1 year 7 months ago #210043
OH and don't dry run the pump!
The following user(s) said Thank You: Toyman
Replied by Roverlike on topic Fuel delivery Problem
Posted 1 year 7 months ago #210044
Unfortunately I'm in Perth. but thanks.
You don't happen to know where the Relay is located, or maybe it does not have one?
Fuel pump relay is part of Engine Management Relay Module. This module consists of 4 relays put together in one box and is located at the rear of the engine ECU. One of these 4 relays if fuel pump relay. There is no separate fuel pump relay on your car.
Posted 1 year 7 months ago #210045
Yeah.......I probably should've mentioned that!
Replied by pandrew3 on topic Fuel delivery Problem
Posted 1 year 6 months ago #210759
Cobber, I noticed your answer about the fuel pump.  I am searching for any details about the fuel pump and have a Mike Satur high capacity fuel pump that I am going to fit as the original pump appears to be faulty.  the question: have you had any experience dealing with the high capacity fuel pump?  Should I fit a fuel regulator?  Mike appears  to be on holidays at the moment and is not answering emails.  MGTF 160 (2002).
Posted 1 year 6 months ago #210761
No I've just had normal pumps so I can't shed any light om high volume pumps, but I have found Mike Satur's communication less then great.
Time to create page: 0.520 seconds
