Mystery plug
Mystery plug was created by 1275rob
Posted 4 days 1 hour ago #210258
folks can anybody help me identify this connector, it feeds out of the ECU loom
by 1275rob
Replied by D4KGP on topic Mystery plug
Posted 4 days 1 hour ago #210259
Hi what model & year is it?
  • Away
Replied by Cobber on topic Mystery plug
Posted 4 days 1 hour ago #210261
What colour wires? and where is it?
It's probably for something that your car isn't fitted with.
Last Edit:4 days 1 hour ago by Cobber
Last edit: 4 days 1 hour ago by Cobber.
Replied by Airportable on topic Mystery plug
Posted 3 days 23 hours ago #210262
By the look & age of ECU it’s probably a Mk1 f & I didn’t recognise the connector, unless it’s the angle from which the photograph was taken, it doesn’t fit comfortably into the family of connectors used on the car.
Even early looms came prepared for facilities not seen on all marks, it could be a refugee from an air conditioning system. That would make sense as not all air con units followed MGR connector conventions.
I’d be interested to know, I can see a bit of research poking it’s nose into my pre Christmas dash to get up to date.
Posted 3 days 22 hours ago #210263
If the wires leading to the connector are blue/slate & purple /slate, then they are AC they are for the cooling fan motor.
Replied by 1275rob on topic Mystery plug
Posted 13 hours 51 minutes ago #210307
Hi its a 1997 Mk1 VVC
by 1275rob
Posted 13 hours 50 minutes ago #210308
Hi the wires are red & black, they come out of the main loom which runs into the ECU
by 1275rob
Posted 13 hours 40 minutes ago #210309
Its a Mk1 VVC, the plug and cable don't look aftermarket and looks OEM and as aged as all the other wiring, it would be good if someone could check their cars and see if there a similar plug
by 1275rob
Posted 12 hours 41 minutes ago #210310
Right Rob, I’m up for that as my car is the same but one year younger & I’m interested.
The following user(s) said Thank You: 1275rob
Replied by Roverlike on topic Mystery plug
Posted 10 hours 53 minutes ago #210315
The only connector that I see fit the shape on your picture is purge control valve on charcoal canister. However wire colours do not match: brown/pink and yellow/orange.
But in this scenario you should be missing connection on purge control valve. Do you miss it?
Posted 9 hours 23 minutes ago #210317
I dont think so but I will double check later as im at work now
by 1275rob
Posted 6 hours 29 minutes ago #210320
I have nothing dangling out at that side of the relay frame. There is the connector for the inertia cut out but the wires are brown & the connector is different.
The wires being red & black, the historic positive/negative is also odd on an original fitment auxiliary. I think you have a foreigner.
Time to create page: 0.707 seconds
