MGF EV Conversion
  • Sessy
  • Novice MGer
  • Novice MGer
MGF EV Conversion was created by Sessy
Posted 4 years 3 weeks ago #199403
I am looking at converting an MGF to EV and am currently looking around for a donor . One that has come up is a 2001 MGF with 6 speed Steptronic gearbox.
Anyone know if any issues using this Steptronic gearbox for EV conversion. Any pros or Cons? .
I intend to keep gearbox and mount motor directly to gearbox input shaft. I guess the Steptronic gearbox is wider than standard gearbox
Thanks
by Sessy
Replied by LRBen on topic MGF EV Conversion
Posted 3 years 11 months ago #199606
Keeping the original gearbox is a decent idea, not sure how an auto box will cope with the motor. I haven't heard of one being used before.
If you are in the UK, I would advise against the MGF as a conversion. The interior dimensions don't lend well to conversion and the DVLA is being a complete pain in the ass. You have to avoid cutting any bodywork or chassis and only use original bolt holes. If they spot something has been cut or drilled you'll need to get an IVA. This is fine for the car but any battery boxes will need certification which is currently costing around £5k.
If you do still want to convert an MGF got for a donor that is pre 2001 tax change. Otherwise you'll still have to pay the original road tax as again the DVLA is refusing to change the tax band of EV conversions post 2001 when the tax is based on Co2 emissions and not engine size.
by LRBen
Replied by talkingcars on topic MGF EV Conversion
Posted 3 years 11 months ago #199617
Hi and welcome to the forum.
Most people use a manual gearbox when converting an ICE car to EV. they then lock it in 3rd gear and rely on the torque of the electric motor.
James
Replied by SteveFMk1 on topic MGF EV Conversion
Posted 3 years 11 months ago #199668
Also, you need to take in to consideration the output of the motor you are going to use. Much more than 120hp and the steptronic gearbox will struggle with the extra power.
Time to create page: 0.423 seconds
