Miniature socket set...?
  • Beth557
Miniature socket set...? was created by Beth557
Posted 12 years 1 month ago #144886
I came to realise this week that a very small, ratchet socket set would be very useful for working on Imelda the Effer so I'm on the hunt.
I've found this...
http://www.eurocarparts.com/ecp/p/tools/car-mechanic-tools/socketry/socket-sets/?SEAAK695&0&t5_329
But I think I want one with a handle even if it's just a couple of inches.
Has anyone got the perfect set they would recommend?
TIA
by Beth557
Replied by John Pell on topic Miniature socket set...?
Posted 12 years 1 month ago #144891
You have got to have the tools to do a good job Beth :-?
Replied by paulsmgf on topic Miniature socket set...?
Posted 12 years 1 month ago #144893
heres a great little set and only £15 at the moment
http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_163049_langId_-1_categoryId_255215
  • Beth557
Replied by Beth557 on topic Miniature socket set...?
Posted 12 years 1 month ago #144902
John Pell wrote: You have got to have the tools to do a good job Beth :-?
I spent some hours this weekend on three bolts, loosening then tightening then loosening, adjusting and then tightening and I was using a little no.8 closed end spanner because that was the only thing I had that fitted the small space I had to work in. Some of the moves were just a tiny fraction at a time. I could have finished the job doing that had I not needed to be at work so yes, if it means I can work faster I'd like to have this tool to hand.
Not unreasonable I feel?? :-?
You have reason to say otherwise??
by Beth557
  • Beth557
Posted 12 years 1 month ago #144903
That looks good Paul but I can't see what sort of dimension the handle is. My current socket set is fairly compact but was too clumsy for the thermostat job. Perhaps the requirement of the thermostat job are unique, hopefully I find the tools before I need to do it again!!
I never want to do it again!
by Beth557
Replied by bensewell on topic Miniature socket set...?
Posted 12 years 1 month ago #144905
I've not failed yet with ratchet spanners + assortment of socket sets. I have 1/4, 3/8 & 1/2 (two sets of both of these). And a shed load of sockets.
Just buy more it makes sense :)
The following user(s) said Thank You: Beth557
Replied by JanCo on topic Miniature socket set...?
Posted 12 years 1 month ago #144911
I've seen micro ratchets in a local motor factor, made by Laser & about 2.5" to 3" long. Probably not great quality but you're not going to be able to put much force on it anyway.
Sealey do a 90mm length 1/4" drive too
Ratchet spanners are essential in my toolbox these days too, especially if you can get them with a flexible head.
by JanCo
Replied by adamelphick on topic Miniature socket set...?
Posted 12 years 1 month ago #144914
I picked up two socket ratchets from Lidl few months back (they have them every now and then) - I think they were £2.99 each or similar.
One was normal sized as a spare but the other was a small one, only about 6" long with a 1/4" drive.... at the same time I also got a set of extension rods, 1/4, 1/2, 3/4 again only a few quid. Lidl (and Aldi) tools are great!
For the tiny sockets I usually go to Poundland as they are good enough for small bolts and 'disposable'!
Last Edit:12 years 1 month ago by adamelphick
Last edit: 12 years 1 month ago by adamelphick.
Replied by Blow-in on topic Miniature socket set...?
Posted 12 years 1 month ago #144919
adamelphick wrote: I picked up two socket ratchets from Lidl few months back (they have them every now and then) - I think they were £2.99 each or similar.
Lidl & Aldi are my usual tool shop too but you need to time it with the offers. I have a Lidl 1/4 socket set with torx and screw driver heads too that is my go to set for fiddly jobs. At these prices you could lose the plastic handle cover and cut down the handle if you wanted to.
Richard
Last Edit:12 years 1 month ago by Blow-in
Last edit: 12 years 1 month ago by Blow-in.
  • Bob
Time to create page: 2.929 seconds
