front anti roll bar bushes
The thicker rollbar is only fitted to the later 85th anni. TFs(Chinese).
- adamelphick
PLEASE NOTE!
If you BUY THIS PART, you are accepting that it is the correct part for your vehicle. Please check before ordering.!
Pictures and illustrations are for your benefit, so please read item details carefully to be sure of correct fit, we will NOT be held responsible for wrong item purchased. Any costs incurred relating to wrongly ordered items will be customers responsibility. We are suppliers of mainly non-standard items. This means that, by their very nature, the parts we supply may not be a straightforward DIY fit. In some cases, modifications or adaptations may be required to achieve an acceptable fit. We therefore recommend that parts we supply should be fitted by a qualified mechanic.
Please "Don't" book your car into a garage before your goods arrive, we will not be held accountable for any financial losses.
unomatt wrote: the bushes do look like the picture, part nimber is correct top so a bit confused. If I manage to get the old ones out I will do a comparison and see if I can figure it out.
The part number NAM9443 appears to be the arb bush for the Metro not MGF. On Rimmer, those parts look to be the same shape as yours and also a similar price whereas the polybushes for mgf are a fair bit cheaper from Rimmer
I'd send them back and tell them that their compatible vehicle list is wrong if I were you.
Robin
The standard genuine mgr bushes are coded as RGX000920
Standard aftermarket as RGX000920P
