Big maintenance
Big maintenance was created by yblokdijk1
Posted 9 years 3 months ago #176597
I'm planning big maintenance on my mgf. I want to replace the cambelt, waterpump, head gasket, oil rail and clutch ( the clutch is still in a good condition) is all this maintenance easy to do with the engine in the car? Or is it easyer to pull the engine out of the car?
Verstuurd vanaf mijn SM-G920F met Tapatalk
Replied by talkingcars on topic Big maintenance
Posted 9 years 3 months ago #176606
Unless they have failed I wouldn't do the clutch or head gasket.
If you need to do them you can do so with the engine in place.
The cambelt and water pump can be done in the car.
Why would you touch the oil rail?
Replied by yblokdijk1 on topic Re:RE: Big maintenance
Posted 9 years 3 months ago #176609
talkingcars wrote: Unless they have failed I wouldn't do the clutch or head gasket.
The headgasket is leaking coolant, so that needs to be done.
A friend of mine ownes a garage and he said that if we need to pull the engine out , that its easy to replace the clutch as well. But is the clutch also removable while the engine stays in the car? Or do i need to lower the rear subframe?
Replied by G0RSQ on topic Re:RE: Big maintenance
Posted 9 years 3 months ago #176634
  • Head gasket can be done with engine in place.
  • Clutch can be done with engine in place
  • Water-pump and cam-belts can be done with engine in place
  • Oil rail can be done with engine in place.
All are a pain with engine in place.
I would replace head gasket, water pump and cam belts only.
Change the clutch when you need to at a later date.
Would not touch the oil rail!
if you insist on doing all the work at once, then maybe easier to remove engine, and do a full engine bay clean up at same time. However removing the engine looks to be a pain, but never had to do it.
Peter
by G0RSQ
The following user(s) said Thank You: yblokdijk1
Time to create page: 1.848 seconds
