Pektron SCU
  • TFZR
  • Apprentice MGer
  • Apprentice MGer
Pektron SCU was created by TFZR
Posted 5 years 5 months ago #195091
Hi,
 my battery was empty and now the TF not starting. The 2 fobs are not acepted from the car. When I connect a new battery the SCU are in alarming mode and I cant read it. On which way I can deactivate the alarmmodus?
greetings from germany
Roland
by TFZR
Replied by shambo on topic Pektron SCU
Posted 5 years 4 months ago #195203
Do you have the EKA code, (Emergency Access Code) for you car? If you do, you can enter it by following the procedure at the bottom of this page link under "How to test the EKA"
http://pscan.uk/features/pektron.html
a copy pasta incase you can't access the site:
How to test the EKA:
1. Lock the car so that the alarm is on, alarm LED on etc. Remove the fob from your key ring and put it somewhere out of radio range of the car; you want to prove that you can do this with just the key.
2. Put the key in the drivers door lock.
3. Enter the first digit of the EKA by turning the key to "unlock" that number of times. So if the EKA is 4321 you turn the key from the centre to unlock and back to centre, 4 times.
4. Enter the second digit of the EKA by turning the key to "lock" that number of times. So if the EKA is 4321 you turn the key from the centre to lock and back to centre, 3 times.
5. Enter the third digit of the EKA by turning the key to "unlock" that number of times. So if the EKA is 4321 you turn the key from the centre to unlock and back to centre, 2 times.
6. Enter the fourth digit of the EKA by turning the key to "lock" that number of times. So if the EKA is 4321 you turn the key from the centre to lock and back to centre, once.
The alarm siren may go off.
7. Unlock the door whilst observing the alarm LED. This will also stop the alarm siren.
If you entered the EKA correctly the alarm LED will illuminate solidly for one second and then continue flashing.
If you entered the EKA incorrectly the alarm LED will just continue flashing without illuminating solidly.
8. Wait for at least five minutes, but not more than ten minutes, turn on the ignition and start the engine.
If you entered the EKA incorrectly then open the door, close the door, lock the door, wait for the alarm LED to flash normally and try again.
After three failed attempts you must wait ten minutes before trying again.
by shambo
Time to create page: 0.481 seconds
