1997 MGF engine specs help
Thanks in advance ☺ .
The dash is because the red line is at 6750? VVT should be at 7250... id sticker says 1.8 VVT but chassis numbers seem to indicate non VVT and CVT bix .. has 5 speed manual.
Cheers Trev
CVT wasn't around in 97.
Your car has a non VVC engine.
- neilpinleeds
Thanks, are they a Honda engine?
No, Rover designed the K Series engine in house. I'm not sure if it pre-dated their involvement with Honda, but if it didn't I still think it was very much a UK effort.
........with an understanding that the oil temperature gauge might not be accurate but it wasn't put there by a cash strapped Rover Group for fun.....
The designers planned for an oil pressure gauge. The accountants went for the cheaper oil temp..
No but VVT is Honda, the MG Rover use VVC.
- BruceTF135
The Rover/Honda collaboration was much earlier. I had a 1982 Triumph Acclaim with a 1335cc Honda twin-carb OHC engine (nice car, if a bit underpowered) and a ghastly Trio-matic gearbox which was neither fully manual nor fully automatic. I believe that it was more or less the same as the contemporary Honda Ballade.
