Thanks to you both for your replies. As you can see below , I’ve got the rear end off the ground as part of my preparation for a replacement post cat O2 sensor coming this week, I thought I’d better get WD40ing the one installed. While having a good look round that area spotted this:
Both sides, rear ARB drop links. Not that I think these are the cause of the aforementioned thuds but obviously they’ll need attention and as the MOT is back end of next month I’d like to get them fixed beforehand. Got both bolts freed off but the lower bolt won’t come out due a certain brake disc being in the way. So, I presume the disc has got to come off, or if I chop/grind said bolt can the replacement be fitted from the back. I’m guessing no to that.
Seems I’ve got some work ahead of me, together with similar thuds from my Freelander plenty of experience changing drop links (they’re coming this week too).
Regards,
Michael.
