Advice please trying to remove the two engine mounting bolts have tried using impact gun with universal joint does it make a difference if I bend over the engine inspection plate to enable a straight line on to the bolt heads as they are at a angle will it make it easier any help greatly appreciated
I understand the application of the uni joint for access but they and any extensions will rob the rattle gun of torque, as they act like torsion springs, using regular pieces form you hand socket set that aren’t designed for use with rattle guns is largely pointless, even using proper rattle gun socket extensions ans accessories wil rob you of torque but at least minimise the loss.
