Alloy wheel refurbishment
- Luckymarine
Do we have anyone on here thats done it? have looked at a few DIY guides online and it seems pretty straight forward if not time consuming and a little OCD which suits me fine.
Managed to get my hands on 4 black 17 inch Ripspeed RS Alloys with tyres for £50, they're a bit battered and bruised so am looking to refurbish them and either give them a go on the TF (via the adaptors) whilst I refurb my own 16 inch 11 spoke or sell them on.
Last Edit:14 years 5 months ago
by Luckymarine
Last edit: 14 years 5 months ago by Luckymarine.
Nope, but its something I'm looking to try on my own wheels when the weather is warm and fine for a while... I don't see it being a quick job mainly due to the drying times of paint and varnish! But it should be easy enough to get a decent finish.
by Tsleight
Replied by David Aiketgate on topic Re: Alloy wheel refurbishment
Posted 14 years 5 months ago #37160
I've done my own for quite a while, and if you can fill and sand, and apply primer and paint on bodywork. You can refurbish wheels.
Luckymarine wrote: ...pretty straight forward if not time consuming and a little OCD which suits me fine.
You sound ideally suited to the task, it does take patience to get good results. You will not be able get the same long term results painting as opposed to powder coating but as long as you apply a good few thin coats of paint then a few coats of lacquer, allowing each to dry thoroughly and lightly rubbing down between each, you can't go far wrong.
Only real problem this time of year is having it warm enough to do the painting, I assume you have a garage/workshop you're going to work in.
Go for it and don't forget to take a few before and after photos
- Luckymarine
I got a cheap set and refurbished myself. I'm very happy with the results. They only cost me some spare time and about £18 in paint and lacquer.
Cut four steel belted radials of the rims.
I took mine down to my tyre fitter, said I'll be back in a week for four tyres, take them old ones off so I can refurbish the rims, here's a fiver, job done
- bryan young
I would do exactly the same, i cut some tyres off rims before and what a job, and they were only textile belting, would not do it again. :evil:
by bryan young
- Luckymarine
Angle grinder with diamond cutting blade should get through them, that coupled with some tyre irons I've got knocking about should do it. If not it will be a trip to the local tyre place and they can do the other 3!
What am I saying, Im the type of person who would spend 4 hours on 1 tyre with a junior hacksaw!
Those tyres will come off....
by Luckymarine
The following user(s) said Thank You: David Aiketgate, bryan young
Time to create page: 0.715 seconds
