How do you fit splitter, advice please
  • Mickle5
How do you fit splitter, advice please was created by Mickle5
Posted 12 years 10 months ago #125723
Just got a fibreglass trophy style front splitter for my mgf (thanks Mr Maltby) question is what's the best way to fit it? Is it some sort of glue job or a few screws? Thanks
by Mickle5
Replied by bensewell on topic How do you fit splitter, advice please
Posted 12 years 10 months ago #125727
Nut n bolt would be best.
Posted 12 years 10 months ago #125728
http://www.the-t-bar.com/en/forum/54-how-tos/1010-kh-splitter-how-to-fit-to-your-mgf
  • Mickle5
Replied by Mickle5 on topic How do you fit splitter, advice please
Posted 12 years 10 months ago #125731
Thanks Ben but mine is the one tat comes up over the original bumper style, I'm not sure how to bond it on without leaving gaps, ie do I need a special glue? Thanks
by Mickle5
Posted 12 years 10 months ago #125732
In that case if its one of those I'd advise putting some TIGER SEAL on it this stuff can stick an elephant to a ceiling it wont come off then.
The following user(s) said Thank You: Mickle5
Replied by David Aiketgate on topic How do you fit splitter, advice please
Posted 12 years 10 months ago #125747
I had an original Trophy splitter fitted and it was bonded to the bumper along the top edge.
  • Mickle5
Posted 12 years 10 months ago #126439
After much swearing and cursing, my good lady and kids staying well away I finally got my new trophy style splitter to fit! I used a mixture of stainless nut and bolts (three across the bottom and one in each wheel arch) and tiger seal. The glue is awesome and after a day I suspect you could stand on it without it budging!
Tip: don't get it on the other paintwork, this results in hours of elbow grease and a hair dryer to soften it! :rant:
Second tip: wear gloves, seems impossible to remove from skin! :oops:
Last Edit:12 years 10 months ago by Mickle5
Last edit: 12 years 10 months ago by David Aiketgate. Reason: clicked insert on photo
Replied by John and Sue on topic How do you fit splitter, advice please
Posted 12 years 10 months ago #126463
Blu Tak or Sellotape is a good way of fixing a splitter. Or Juicy Fruit chewing gum.
It will then fall off at the first bump, you will drive over it and smosh it into splinters.
Then there will be one less splitter on the planet. :broon:
:coat:
Replied by Andy Lawrence on topic How do you fit splitter, advice please
Posted 12 years 10 months ago #126466
I think we should all chip in and buy John one for Christmas.
:oops: :coat:
WHALE OIL BEEF HOOKED
Replied by talkingcars on topic How do you fit splitter, advice please
Posted 12 years 10 months ago #126467
John and Sue wrote: Blu Tak or Sellotape is a good way of fixing a splitter. Or Juicy Fruit chewing gum.
:coat:
An F without a splitter handles like dentures without fixative chewing gum!...........Badly.
Posted 12 years 10 months ago #126472
When I removed a trophy splitter from a scrapyard car it was held on with double sided sticky foam (5mm), the same stuff was used on the MG bits on my wifes ZR. In the arches were screws and underneath some christmas tree clips.
I got some from ebay, carefully removed the residue of the old stuff borrowing Mrs TC's hairdriver to soften the glue, applied the new to the splitter, with the aid of Mrs TC we held the spoiler to the car and then carefully peeled away the other backing as I pushed the spoiler onto the car.
I then added a couple of screws on either side in the wheel arch, on the underside I drilled a few holes and used cable ties instead of christmas trees.
The splitter was then subjected to a pan european testing from snow in the alps to 30's in Italy, heavy rain and autobahn speeds with no ill effects.
Time to create page: 0.745 seconds
