Seats - How to remove and refit.
Replied by talkingcars on topic Re: To remove and refit the seats.
Posted 15 years 3 months ago #22402
I found it easier to do the rear bolts first as the seats slide back more easily without the rear bolts than it does going foward without the front bolts.
Replied by toby2fly on topic Re: Seats - How to remove and refit.
Posted 15 years 3 months ago #22796
I removed the drivers seat only but did not disconnect the battery first. I disconnected the connector under the seat and re-fitted it on putting the seat back with no ill effects. Do I need to do anything now. Will the SR work
Replied by bryan young on topic Re: Seats - How to remove and refit.
Posted 15 years 3 months ago #22804
toby2fly wrote: I removed the drivers seat only but did not disconnect the battery first. I disconnected the connector under the seat and re-fitted it on putting the seat back with no ill effects. Do I need to do anything now. Will the SR work
If the SRS light on the dash display goes out, there is a good chance all is ok. ~ i beleive that the reccomendation to dissconect the battery first is to avoid any possibility of an air bag firing. i have heard of people just blundering in without any dire results. :ohmy:
Replied by bensewell on topic Re: Seats - How to remove and refit.
Posted 14 years 1 month ago #50297
That back bolt is a right sod!
  • Jimuth
  • "So, how much is that going to cost?"
Replied by Jimuth on topic Seats - How to remove and refit.
Posted 13 years 4 months ago #104606
Is there any knack or technique to removing the bolts - only got 1 off so far.
The others aren't shifting at all, and it's making me feel more weedy than normal :rant:
Ebay + Nectar = lots of MGF points
by Jimuth
Replied by Fred on topic Seats - How to remove and refit.
Posted 13 years 4 months ago #104610
Mine were stuck but a quick smack on the ratchet handle with the palm of my hand cracked them. If that doesn't work give it a smack with a hammer to crack them and then wind out as normal. They are quite stiff all the way out though.
by Fred
The following user(s) said Thank You: Jimuth
Replied by cp53 on topic Seats - How to remove and refit.
Posted 13 years 4 months ago #104623
Dont knacker the bolt quid a go they are,that two quid you may need it..
by cp53
Replied by Fil6909 on topic To remove and refit the seats.
Posted 7 years 1 month ago #190695
About to start this job, however ..'noting any codes ' .....? .. how are they presented ? Thanks
by Fil6909
Replied by The driving dutchman on topic Re:Seats - How to remove and refit.
Posted 7 years 4 weeks ago #190726
Allways told to wait 15 min after disconnecting the battery.
Top tip: you can take out the complete seat with the safety belt still fitted. Its much easier to unbolt the safety belt with the chair standing next to the car!
Verstuurd vanaf mijn SM-G950F met Tapatalk
Last Edit:7 years 4 weeks ago by The driving dutchman
Last edit: 7 years 4 weeks ago by The driving dutchman.
Replied by talkingcars on topic To remove and refit the seats.
Posted 7 years 2 weeks ago #190770
Fil6909 wrote: About to start this job, however ..'noting any codes ' .....? .. how are they presented ? Thanks
Depends on your make and model of headunit.
Replied by talkingcars on topic Re:Seats - How to remove and refit.
Posted 7 years 2 weeks ago #190771
The driving dutchman wrote: Allways told to wait 15 min after disconnecting the battery.
The official advice from MGR was disconnect the battery and wait 10 minutes before touching any part of the SRS system..
The following user(s) said Thank You: The driving dutchman
Replied by Fil6909 on topic Re:Seats - How to remove and refit.
Posted 7 years 2 weeks ago #190780
Cheers , finally get my refurbed leather driver seat back Thursday ,so up & at it over the weekend 👍
by Fil6909
Time to create page: 0.507 seconds
