Engine access cover - How to remove(with Hoops)
Engine access cover - How to remove(with Hoops) was created by David Aiketgate
Posted 14 years 1 month ago #17749
Clive's excellent How to shows how to get to the engine, if you have the standard TBar and crossmember with the speaker box.
If you have most types of Hoops fitted it is usual that the original crossmember and speaker box is replaced.
This actually makes engine access easier.
Unzip the plastic window and ease the top out of the hood.
Last Edit:14 years 1 month ago
by David Aiketgate
Last edit: 14 years 1 month ago by David Aiketgate.
Replied by David Aiketgate on topic Re: Engine access cover - How to remove(with Hoops)
Posted 14 years 1 month ago #17750
Roll it back to give access to the 5 clips that hold the rear hood bar. Release the clips.
You can now hinge the rear bar up and forwards, laying the window on to the top of the soft top.
by David Aiketgate
Posted 14 years 1 month ago #17752David
Posted 14 years 1 month ago #17753David
by David Aiketgate
Posted 14 years 1 month ago #17754
Because the speaker box is absent, Access to the 3x 10mm bolts under the crossmember is possible with a 1/4 drive socket or a ratchet spanner.
Remove the rest of the 11x 10mm securing bolts and lift the access cover off. You will need to manouevre the edge of the cover past the clips.
by David Aiketgate
The following user(s) said Thank You: BigPhil
Replied by Fiddler on topic Re: Engine access cover - How to remove(with Hoops)
Posted 4 years 6 months ago #193658
I think mine has been off since I got the car a few months ago . Anyone drive around with it permanently removed .
So much messing to do .why not . Too hot?
by Fiddler
Replied by Cobber on topic Re: Engine access cover - How to remove(with Hoops)
Posted 4 years 6 months ago #193659
Heat is but 1 reason, there is potential for fumes causing problems, engine bay aiirflow may be adversely affected, little to protect the occupants from boiling coolant in the vent of a cooling system failure or fire in the case of a fuel line failure and loss of body rigidity (you'd be surprised how much difference a flimsy bit of tin can make when properly secured)
The following user(s) said Thank You: David Aiketgate, Fiddler
Time to create page: 0.511 seconds
