Pressure Relief Thermostat (PRT) - How to Replace
Replied by Airportable on topic Pressure Relief Thermostat (PRT) - How to Replace
Posted 2 years 10 months ago #204032
It’s not necessarily the stuff that can be temperamental, it’s invariably the hands of the applier that won’t do as instructed. They are too large, in the wrong position & will not work when in the right, you are underneath with water dripping in your eyes, which are already half closed & the screwdriver is an inch out of reach & can only be retrieved by wriggling out & starting again. I have a pit in my garage but insufficient spring left in my legs to get out once in, however the above still apply to me although I can sit on a small stool & that means craning my neck (not good) whilst the jackers up can lay on their backs.
If you start off MG ownership hale & hearty with a determination to look after it yourself, you will soon accrue some small disability, in addition to cuts, abrasions, burns & bruises.
Last Edit:2 years 10 months ago
by Airportable
Last edit: 2 years 10 months ago by Airportable.
Posted 2 years 10 months ago #204048
Sorry Matt just a day late. If you have a rag top roadster & the sun is shining you take full advantage of both. Right the PRT picture I promised.
by Airportable
Last edit: 2 years 10 months ago by Cobber.
Replied by b-havers on topic Pressure Relief Thermostat (PRT) - How to Replace
Posted 1 year 5 months ago #210856
Is there a specific VIN or date, when the PRT was taken into use as standard?
by b-havers
Posted 1 year 5 months ago #210865
There's no point in discussing ''standard'' with me, standard things inspire me to change them & lean on route.
Roverlike is the fount of all update points & chassis numbers.
by Airportable
Replied by Roverlike on topic Pressure Relief Thermostat (PRT) - How to Replace
Posted 1 year 5 months ago #210868PRT was used starting from VIN 622951 which corresponds with date 13/08/2003.Is there a specific VIN or date, when the PRT was taken into use as standard?
by Roverlike
Time to create page: 0.406 seconds
