EKA CODE - How to use the emergency key access
EKA CODE - How to use the emergency key access was created by David Aiketgate
Posted 14 years 3 months ago #44246Some helpful Notes.
When turning the key in the lock it must be done with precision and slowly. On some worn locks, you may have to turn the key slightly past the central upright position.
If you listen closely you should be able to hear the switches clicking inside the lock.
Sometimes you need to add one digit to the second and fourth digits of the EKA code, as the MGR database has sometimes not been accurate
For entering accuracy, it's quite useul to nudge the key ever so slightly past the centre mark, to ensure that the lock has registered a zero point
- Leigh Ping
Online
Replied by Leigh Ping on topic Re: EKA CODE - How to use the emergency key access
Posted 14 years 3 months ago #44309MGF, MGTF Emergency key access - EKA CODE - How to use the emergency key access.
Replied by Pcbaker65 on topic Re: EKA CODE - How to use the emergency key access
Posted 13 years 8 months ago #82003Please Log in or Create an account to join the conversation.
Replied by Marmite on topic Re: EKA CODE - How to use the emergency key access
Posted 13 years 8 months ago #82013Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Re: EKA CODE - How to use the emergency key access
Posted 13 years 8 months ago #82015Doesn't help you in Australia though.
Posted 13 years 8 months ago #82019Please Log in or Create an account to join the conversation.
Replied by Shutts on topic Re: EKA CODE - How to use the emergency key access
Posted 13 years 8 months ago #82125That's how I got mine.
:woohoo:
Don't know if they will supply to Oz but worth a try.
Hope you get it sorted.
Some days you are the pigeon and some days you are the statue.
Posted 13 years 8 months ago #82131David
Posted 13 years 8 months ago #82169Many thanks. But the glovebox?
My glovebox?
Phil
- a Guest
- User
Replied by a Guest on topic Re: EKA CODE - How to use the emergency key access
Posted 13 years 8 months ago #82174Please Log in or Create an account to join the conversation.
Posted 13 years 8 months ago #82175Please Log in or Create an account to join the conversation.
