Suplex Suspension - How to fit.(But Don't!)
Offline Topic Author
Replied by David Aiketgate on topic Re: Suplex Suspension - How to fit
Posted 12 years 2 months ago #46264Indeed, Suplex insist that the whole kit is fitted together, they even prohibit using the kit with lowering pins as this takes the dampers outside their effective working range.
Apparently, the Springs are progressive, so that lower means stiffer.
They state that using these kits on a Trophy, and setting up in the above manner will set the suspension height in the range for Trophy spec.
I can only think that the difference in stiffness between the Trophy hydragas and the Suplex setups will be very noticeable.ie much softer/compliant. This will mean a much more comfortable ride but it will be totally subjective as to how the Trophy owner reacts to this.
- p24hrsmith
Replied by p24hrsmith on topic Re: Suplex Suspension - How to fit
Posted 12 years 2 months ago #46339Please Log in or Create an account to join the conversation.
Posted 12 years 2 months ago #46356I can't adjust the fronts up to the height I want. They are on full adjust and the height is 345mm. At that, the springs are under no tension and rattle like f... flip over every bump. :rant:
I am going to take the fronts off and put the spacer back on the pin. I hope that sorts it, or I may go critical and explode.
Now it's got me wondering if I have lowering pins fitted, so once the first can is off again its time to measure the pin. :rant:
HELL AND DAMNATION!
Posted 12 years 2 months ago #46357David
- Tourbillon
Replied by Tourbillon on topic Re: Suplex Suspension - How to fit
Posted 12 years 2 months ago #46366Please Log in or Create an account to join the conversation.
- p24hrsmith
Posted 12 years 2 months ago #46370Please Log in or Create an account to join the conversation.
Posted 12 years 2 months ago #463802/.That you need the spacer to achieve a suspension height over 350mm :rant:
Posted 12 years 2 months ago #46399Rears adjusted to 345mm.
Everything back together and took the car for a test drive, and...
:woohoo: :woo2:
Thunderbirds Are Go! :broon:
So far the ride is much more forgiving, yet still sporty. Cornering gives no more roll than before. Deals with our uneven country roads with definitely less spine jarring than the previous hydragas setup, and takes speed bumps in its stride.
I'll report again when we've put a few hundred miles on the car. :yesnod:
for you......
could be bad news for me when I tell the missus I WANT these :lol:
Posted 12 years 2 months ago #46406David
- bryan young
Replied by bryan young on topic Re: Suplex Suspension - How to fit
Posted 12 years 2 months ago #46435Please Log in or Create an account to join the conversation.
bryan young wrote: you should never leave bits out !!!!! :whistle:
thats a bit harsh bryan :bust: every one likes to experiment :broon:
nice one just a pitty they are the price of an F :omg:
mad about cars and bikes
if it aint broke dont fix it
