Gear cables Bell crank fittings- how to replace.
Gear cables Bell crank fittings- how to replace. was created by David Aiketgate
Posted 11 years 7 months ago #112399Jack up the rear of the car, and fit axle strands to secure the car.
Just forwards of the Cat and just to the nearside of centre you'll see this.
This little gizmo translates the movement of the two gear cables into gear changes in the gearbox.
The two ball joints are highlighted above and in this photo from further away.
I also purchased two new cable end boots as the originals had definitely seen better days.
I used a sharp bade to cut away the remnants of the boot and exposed the cable and the fixing.
The cable end is threaded to take the the ball joint and there is a locknut securing the ball joint to the cable.
Using a large flat bladed screwdriver pop the old ball joint cup off the ball.
Using two 10mm open ended spanners hold the locknut steady and undo the rosejoint. This way means that the locknut is retained in the correct position for replacement without fiddling with adjustment. Once you have freed the joint you can wind it off the cable end by hand.
Replied by David Aiketgate on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112409Check the operation of the gears.
Repeat with the other balljoint.
That's it, in theory.
In practice, the problem I found was that one of the new balljoints had a longer shaft than the old one.
This means that my careful retention of the lock nut in position was redundant. :rant: I fitted the new balljoint, screwing it up to the locknut, but the result was that reverse gear wouldn't engage.
So I measured the total length difference and wound the locknut farther onto the cable end to compensate for the difference.
The result of that was that I had reverse again.
Of general interest is that I wound the balljoint on one more thread and found that reverse gear is now much easier to engage.
So for people suffering with a grinding reverse gear they could solve it by popping the balljoint off and winding it further on 1 thread.
Here are the remains of the originals with all the pieces of the boots.
Posted 11 years 7 months ago #112410David
Replied by mowog73 on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112428[size=10pt]Mark[/size]
95 MGF
Posted 11 years 7 months ago #112431David
Posted 11 years 7 months ago #112634Reverse just slips in nicely and easily now, instead of the previous " Ram it in! - is it in? - Grinnnnnnd!"
- a Guest
- Visitor
Replied by a Guest on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112649Please Log in or Create an account to join the conversation.
Replied by Uncletone on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112661I have an issue with reverse gear I just have to make sure its in. I didn't think you could get the end joints, I will order said boots but where do we get the ends from Rimmers and B&G don't seem to list them.
Tone
Replied by cairnsys on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112669Uncletone wrote: Thanks David,
Tone
Only place I've found them so far is here
http://www.amazon.co.uk/MGF-MGTF-Gear-Cable-Connectors/dp/B005JSYT2I/ref=sr_1_sc_1?ie=UTF8&qid=1365109980&sr=8-1-spell&keywords=mgfgear+cable
They are Portland ones - I think this is their website https://www.ptecarparts.co.uk/
And Mike Satur sells the rubber noots (out of stock when I last looked though).
Robin
Posted 11 years 7 months ago #112674David
Posted 11 years 7 months ago #112678Bell Crank Assembly, rear - MGF
ET7480
Price: £29.99 (Excluding VAT at 20%)
Gearbox bell crank assembly.
Upgraded part.Improves gear selection.
(please note 2 rod ends supplied with this kit)
- Leigh Ping
- Online
Replied by Leigh Ping on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112679Please Log in or Create an account to join the conversation.
