Gear cables Bell crank fittings- how to replace.
Replied by Uncletone on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112701I'll bite the bullet and order from Mike & Rimmers
Tone
Replied by cairnsys on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112869David Aiketgate wrote: Those Portland prices make the Mike Satur bell crank a bargain.
Bell Crank Assembly, rear - MGF
ET7480
Price: £29.99 (Excluding VAT at 20%)
Gearbox bell crank assembly.
Upgraded part.Improves gear selection.
(please note 2 rod ends supplied with this kit)
I'm thinking of going down the Mike Satur Bell Crank route because of the cost. I'm wondering if it's going to be worth fitting the Bell Crank as well and how much of a job it will be. Or just use the rod ends.
Robin
Posted 11 years 7 months ago #112894Tone
Replied by David Aiketgate on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #112902Pop it on again.
Posted 11 years 7 months ago #114659Very dainty. Problem with boots, they've sent two the same size, when in fact one is bigger than the other. The cross gate one is a bit bigger.
Fitting the bell crank is straightforward, just follow the instructions nothing too difficult knock the old pin out, remove the ends leaving locking nuts as they are for a rough starting point and reassemble. Although in saying that Tourbillion (Neil) had a struggle with removing his roll pin. I had a small blow torch handy in case, but as it happened mine turned out to be relatively easy. From getting it on the ramps, to taking it down for a test run 45 mins in total.
I have to admit looking at the new bell crank, that at first I was a little sceptical, the Mike Satur kit is OK, but the ends are a quarter the size of the originals, but they work fine. It does mean that the setting up requires a little more time and adjustment as you cannot fit them exactly as they came off.
Only time will tell, but what has stood out is the quality of the gear change. I don't think we realise sometimes just how sloppy the change gets thro' wear and tear.
Well pleased and well impressed. I just need to contact Rimmers to see if I can swop one of the boots now.
Tone
Replied by Bob on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #114665Please Log in or Create an account to join the conversation.
- philljoynes
Replied by philljoynes on topic Re: Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #114715Please Log in or Create an account to join the conversation.
Replied by David Aiketgate on topic Re: Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #114722BOOT-GEAR CHANGE CABLE-MGF/MGTF ULS000012 (Rimmer Bros part number)
- John and Sue
Replied by John and Sue on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #114732Dedication to the marque Sir: I salute thee.
Posted 11 years 7 months ago #114743:yesnod: Sorting out a few photos to put up., with a G&T!
- philljoynes
Replied by philljoynes on topic Gear cables Bell crank fittings- how to replace.
Posted 11 years 7 months ago #114781http://www.rimmerbros.co.uk/Item--i-ULS000012
Also does anyone konw which part number I need for the boot that goes between the bell crank assambly and gear box rod it fixes to (I hope that is correct, please feel free to correct if not)?
I have spoken to Rimmer Bros but they didn't give me huge confidence.
Posted 11 years 7 months ago #114788David
