Fitting a full harness
- Diesel Destroyer
Bigwigsdad wrote: Ok you have persuaded me again
Like you say it's better to have the option without it being fully tested.
So new pipes, SS hoses, drilled & grooved fronts, std rears with green stuff pads all round and a lever bias valve... I think I might need to get a seatbelt harness
Fitting harnesses into an F/TF is near on impossible without a cage (to meet MSA regs anyway) and an insurance mine field
Another.. Easier option is these http://www.cg-lock.co.uk
E mail Graham there.. Currently on special.. I've just ordered a pair for £67 delivered
I never got on that well with the cg-lock - but a full harness is something else. Not impossible to fit, although to do this properly you'd need a robust bar running between the upper seat belt mounts: the Mk1 X-Power roll hoop mounting bar is just about perfect for this :broon:
- Diesel Destroyer
How would you mount harness via a bar between the two factory seat belts?
Just curious
Best option would be 3 point harnesses.. With the rear mount on the far side of the engine cover.. But there is not enough material to fix to there.. So the mount could go on the vertical section.. But this would need beefing up.. And accessing behind it would be difficult..
Pics please..
I don't have any pix of the setup, in fact I only have a few of the car, here's one.
It was powered by an MGA twincam. It wasn't one of our more, successful cars!
If the mounting pointa for the individual shoulder straps are at the right height for the driver it doesn't matter.
Open wheelers don't have the shoulder strap mounting point a long way back.
