Alternator adjuster bracket - How to upgrade
Replied by David Aiketgate on topic Alternator adjuster bracket upgrade
Posted 12 years 1 month ago #143945
Here's a close up of the original bracket.
The bracket is attached at the engine block end with a 13mm hex bolt; the alternator end with a 15mm nut on a long bolt through the alternator body.
Remove the 13mm bolt and the 15mm nut. Remove the oem bracket.
In theory you simply need to adjust the new item to the same length as the original and refit using the bolt and nut.
There is a small issue, however, in that the new rose joint ends are substantially thicker than the oem bracket. On the engine block end, the usable threads are reduced by about 50% (about 10-15mm) so you could reuse the bolt. I sourced a longer bolt to restore the lost threads
Here you can see a comparison of the different thicknesses.
On the alternator end, there is not sufficient bolt length to fit the rose joint and the nut. You will need to source a longer bolt to fit this product. Again I found a longer bolt
Here is the new adjuster in place.
Adjusting the alternator belt is now much easier!
Last Edit:12 years 1 month ago by David Aiketgate
Last edit: 12 years 1 month ago by David Aiketgate.
The following user(s) said Thank You: Bob, cairnsys, GT MG SPARES LTD, graham1, smutekh
Replied by GT MG SPARES LTD on topic Alternator adjuster bracket upgrade
Posted 12 years 1 month ago #143946
Thanks David should save a few knuckles on the OE 15mm not come across these before,looks a good easier upgrade.
Last Edit:12 years 1 month ago by GT MG SPARES LTD
Posted 12 years 1 month ago #143947
Agreed, that 15mm nut is so ******** awkward to get at! :bang: :rant:
Replied by helsbyman on topic Alternator adjuster bracket upgrade
Posted 12 years 1 month ago #143948
Ha I don't have an adjuster on my TF so I will not need this up grade :pop:
Posted 12 years 1 month ago #143949
You must have aircon.
Posted 12 years 1 month ago #143955
GT MG SPARES LTD wrote: You must have aircon.
No air con
Posted 12 years 1 month ago #143956
Are you getting charge from another source
Posted 12 years 1 month ago #143974
No
was never on the car from new as no one has touched that part of the car
Posted 12 years 1 month ago #143977
:-? what wasn't on the car?:shrug:
Posted 12 years 1 month ago #143978
David Aiketgate wrote: :-? what wasn't on the car?:shrug:
the adjuster bar for the alternator
Posted 12 years 1 month ago #143981
Really? Then you should get one of these or an oem fitted. The strain on the other fittings will not be doing any good. :nonod:
Time to create page: 0.783 seconds
