Rear brakes upgrade to AP - THEORETICAL ONLY
Rear brakes upgrade to AP - THEORETICAL ONLY was created by David Aiketgate
Posted 9 years 11 months ago #154167
Theoretical only. This change requires alterations to the hub which may weaken it. Do not attempt to do this on your car!
As I have a spare set of AP callipers i thought i would see how much work would be involved in fitting 304 discs and Aps to the rear.
The first issue is the obvious one - No handbrake. So I have ordered a set of additional spot callipers from Hispec. When they arrive I will detail how they would be fitted to the hub.
The next issue surprised me a little - the fixing holes in the hub don't line up with the threaded fixing holes in the APcalliper. The rear hub holes are at a wider spacing than the AP holes. So they would need to be redrilled. Further, even with the holes in the right place the callipers still won't fit without some re-shaping of the hub fixing area..
That's all for now. Thought people might be interested.
Is my assumption correct that reworking the hub fixing holes is a much better idea than trying to rework the calliper holes?
Last Edit:9 years 8 months ago by David Aiketgate
Last edit: 9 years 8 months ago by David Aiketgate.
Replied by David Aiketgate on topic Rear brakes upgrade to AP
Posted 9 years 11 months ago #154168
ps Safety notice
I am playing with a spare hub assembly, not the one on the car :nonod:
Last Edit:9 years 11 months ago by David Aiketgate
Last edit: 9 years 11 months ago by David Aiketgate.
Replied by Fatbaldingoldgit on topic Rear brakes upgrade to AP
Posted 9 years 11 months ago #154170
David..won't you need to space the callipers out from the hub centre anyway..for the larger discs..in which case you will need to fabricate a bracket with compatible holes for the hub at one end and holes for the callipers at the other..It doesn't matter that the callipers holes don't marry with the hub holes....you may also need to offset or inset the callipers to centre the discs..The trickiest bit is fabricating the brackets so everything is in alignment.. :yesnod:
- Frank Zappa
Posted 9 years 11 months ago #154172
No. AFAIK, the AP calliper is in the correct position in relation to the hub and disc, just the holes don't match up. If you think about it the aps fit straight onto the front hubs without spacing. Obviously I will need a bracket/spacer for the spot handbrake calliper.
Replied by cairnsys on topic Rear brakes upgrade to AP
Posted 9 years 11 months ago #154177
Sounds an interesting project but isn't an easier upgrade path to use 280mm discs like those from MGFMania?
Of course if you already have a pair of APs sitting there doing nothing....
Posted 9 years 11 months ago #154178
It's certainly easier to go the '280mm disc with the blocked out calliper' route. However you still have the crappy original rear calliper... and I already had a set of APs spare, so :shrug: :lol:
Posted 9 years 11 months ago #154179
True (crappy rear caliper).
I'm intrigued to know how and where the AP and additional spot caliper will fit. Will you have to mount the AP on the leading edge of the disc so that the handbrake cable routes to the same location for the spot caliper? Or am I totally not understanding (highly likely) how the additional caliper works.
I watch with interest :yesnod:
Posted 9 years 11 months ago #154181
The Ap calliper is THEORETICALLY attached in the same position as the original. The handbrake calliper will be theoretically fitted at a position where a theoretically re routed handbrake cable would fit. In theory, of course.
Posted 9 years 11 months ago #154182
Sounds great fun - theoretically :lol:
Posted 9 years 11 months ago #154186
Replied by stephenj on topic Rear brakes upgrade to AP
Posted 9 years 11 months ago #154238
It seems dangerous to me as you run the risk of rear end loch up and visiting the nearest roadside hedge
Replied by mgbv8mike on topic Rear brakes upgrade to AP - THEORETICAL ONLY
Posted 9 years 11 months ago #154253
Surely not with ABS ?
My TF is definitely underbraked at the rear, ABS comes in on the fronts (4pot) when I anchor it in anger, bigger rears must be an improvement.
Time to create page: 0.543 seconds
