Fob Battery & Keyfob Case Replacement
Fob Battery & Keyfob Case Replacement was created by cjj
Posted 13 years 7 months ago #23914
There are a couple of reasons that you might want to change your alarm fob batteries.
It is actually part of the service that the battery gets changed every 15k miles (or 12 months) on a TF). More usually though, the first time you will even think about the fob battery is when the fob starts playing up. If you are lucky, you will notice that the range of the fob is getting less and less, or that the operation is a bit erratic. So, stop putting the fob against your head and standing on one leg and invest a couple of quid in a new fob battery.
The battery is common on most fobs and easy to get hold of.
It is a CR2032 and is a 3V battery.
There are different types of fob, but the two I have are the round type and the square type (technical terms). If you have anything else then the procedure will be similar.
The round type is the most complicated, but is still easy.
On the rear of the fob there is a little recess
Which is just the right size for a screwdriver blade
Push the screwdriver into the recess and turn the screwdriver. This should release the lower cover.
Which can then be removed.
Revealing two little plastic clips on the sides which you can carefully unclip with the screwdriver.
This allows the fob to open up revealing the circuit board and battery
Now use the screwdriver to lever the battery out of the holder, noting which way round it is. Positive is the side with the writing on and faces down.
Replace with a new battery
Clip the two halves of the cover back together
And push the lower cover back on, making sure it is the right way round.
And that is it
The older, squarer, fob is easier to do.
If you look around the edges of the fob you will notice a join that goes all the way around the edge.
Push a flat bladed knife into the join
And twist, forcing the 2 halves apart. Be careful here not to deform the plastic
Once apart, you will see the battery held in a metal holder.
Slide the battery out of the holder, noting which way the battery sits. The positive side, with the writing on, faces you.
Replace with a new battery and simply push the 2 halves together until they click and you are done.
One thing worth mentioning at this point is the fob re synch procedure.
It has never happened to me yet, but if the fob fails to operate it may be down to the fob becoming out of sync with the alarm unit.
To re sync the fob, make sure the car is unlocked and press either of the fob buttons 4 times until the locks operate.
Last Edit:12 years 6 months ago by cjj
Last edit: 12 years 6 months ago by Leigh Ping.
The following user(s) said Thank You: bryan young, Leigh Ping, c.steffan, DENGY
Replied by talkingcars on topic Re: Fob Battery Replacement
Posted 13 years 7 months ago #23925
The battaries are dead cheap on eBay.
de sync normally occurs if you leave the battery out for to long and the fob becomes discharged.
Replied by David Aiketgate on topic Re: Fob Battery Replacement
Posted 13 years 7 months ago #23926
Nice one, Clive!:yesnod:
Replied by adamelphick on topic Re: Fob Battery Replacement
Posted 13 years 7 months ago #23928
Nice guide for the newbies but there's a safer way to open the square fob without risking deforming the edges of the case - just where the ring attaches there's a slot between the two halves designed to put a knife/slim screwdriver in to - then just pop it apart!
Last Edit:13 years 7 months ago by adamelphick
Last edit: 13 years 7 months ago by adamelphick.
The following user(s) said Thank You: psymon, bryan young
Replied by Gadget2466 on topic Re: Fob Battery Replacement
Posted 12 years 11 months ago #36162
What happens if the fob gets de-synced. Mine is flat so switched to the other until I can get a battery - just not got round to it for a few weeks though, so I suspect mine will have De sync'd.
How do you get it back in sync with the alarm......?
Thanks all
Gary.
Posted 12 years 11 months ago #36172
You just need to repeatedly press the lock button until the central locking works.
I have two fobs and one is a spare that only gets used once in a blue moon, but after a couple of presses it works OK. :thumbsup:
Replied by bryan young on topic Re: Fob Battery Replacement
Posted 12 years 11 months ago #36174
David Aiketgate wrote: You just need to repeatedly press the lock button until the central locking works.
The "book" says that you have to discharge the fob after taking the old battery out by pressing both buttons for 10 seconds, insert new CR2032 battery and press 4 or 5 times near the car to restet the rolling code. :thumbsup:
Replied by Leigh Ping on topic Re: Fob Battery & Keyfob Case Replacement
Posted 12 years 10 months ago #39490
Added a couple of explanatory videos to the original picture guide above. :broon:
The following user(s) said Thank You: robh, judiths handyman
Time to create page: 0.647 seconds
