Fob playing up?
Fob playing up? was created by adamelphick
Posted 14 years 6 months ago #33737
If your fob is playing up and changing the battery only seems to temporarily improve things check the three solder points on the battery cradle - they may be dry joints!
I re-soldered Meg's and never had the issue again!
You need to use a little flux and some electrical cored solder. Be careful not to heat the area too much or you may damage the printed circuits.
Last Edit:6 years 2 months ago by adamelphick
Last edit: 6 years 2 months ago by adamelphick.
The following user(s) said Thank You: David Aiketgate, rog1963, Leigh Ping, Tsleight
Time to create page: 0.375 seconds
