Passenger door lock jammed - Solved.
- bryan young
Replied by bryan young on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 4 months ago #43492Softly~Softly wrote: Can you do a "How too, Not too" as well please
Sailing a bit close to the wind with that one!!!!!
- a Guest
- User
Replied by a Guest on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 4 months ago #43493Besides it's something I really would not like to "Have too" I never realised the implications before :ohmy:
Can the car still be used with that door locked
- Tourbillon
Replied by Tourbillon on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 4 months ago #43509Have you tried to connect small bore tubing to silicon lubricant can and hose the lock with it from going down from the top. I know the internals may be knackered but if you can just get enough function to release the superlock. just and idea but my lock was erratic so i got the door card off and blasted it with Silicon and it worked better for a while ( i did end up changing it as the silicon washed out and it started making machine gun noises again. Maybe a case for a metal coathanger and thin tube.
BTW i have a spare passenger lock in my garage which you can have FOC as i got it free. PM me with and address if you want it.
N
- adamelphick
Replied by adamelphick on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 4 months ago #43510Tourbillon wrote: Adam,
N
I'll give it a go... have to stay away from it a few days or I may smash it to bits in my anger methinks! Thansk for the lock offer , but the annoying thing is I have the porginal lock - just didn't think to swap them over when I changed the door!
Oh and I'll try and remember some pics for a How To!
- adamelphick
Posted 14 years 3 months ago #44041Please Log in or Create an account to join the conversation.
- a Guest
- User
Posted 14 years 3 months ago #44042Remember keep calm and don't stress
Replied by Tsleight on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44054[img]i54.tinypic.com/2hdto4p.jpg[/img]
- adamelphick
Posted 14 years 3 months ago #44068Firstly I noticed that if i wanted to be able to lever the door panel off safely I'd have to somehow be able to get down behind it. So I levered the silver/rubber trim off the top of the card (pic is after the card came away but you have to EASE it out of the very small gap by the glass channel to start with!):
I took out the passenger seat and sat it outside the car (the seatbelt is long enough to stay connected!). Then I got inside the car and eased the door rubber seal away to give me some space:
Next I used a small toffee hammer to get the rear 'lugs' to pop. Put the rear part of the hammer against the screw and simply lever it!
You can then easily get the door panel to come away form the door at the rear (leave the front screw IN PLACE and DO NOT try to remove the panel yet!). Now you can begin to peel the door plastic liner back (annoyingly I had only just put it back and sealed it up!):
You can now get into the interior of the door:
Circled is the offending little sod!
You need to disconnect the power to the lock and you may just be lucky enough (I was after an hour of fiddling and tapping and squirting with WD40) that the bugger unlocks. Below is the connector you need to pull apart:
As I said above after fiddling for an hour this happened:
Once it had opened I immediately took off the lock, and also undid the front door panel screw and put the panel to one side. Its easy enough so I didn't take pics. But basically you undo the 3 star bolts on the door end, then unclip the outside handle rod, and then ease it out past the window channel (you MAY need to undo the TOP two window channel nuts and move it forwards slightly to get some space. Then you can get the interior door handle cable off the lock too.
As it happens Meg's orginal lock went faulty just after I refitted it (unbelievable I know!). So I then spent another hour making up a good lock from 3 I had in the shed! One had a grey set of stepper motors and another had a lovely smooth mechanism - so I combined the two and voila! I refitted as a reverse of the above. All was working well!
So I refitted the chrome/rubber top strip to the door card and then began to pop it all back together. I was so happy until I noticed this:
I managed to chip the door pocket that I had only just resprayed (after chipping it last year)...... GRRRRR. Anyway at least she now opens and closes properly!!!
Replied by David Aiketgate on topic Re: Passenger lock jammed - yes you guessed it LOCKED!
Posted 14 years 3 months ago #44073There are a number of people who have ended up in your position, but have destroyed the door card.
Was there much/any damage to the card/fittings using this method?
- adamelphick
Posted 14 years 3 months ago #44075Please Log in or Create an account to join the conversation.
Posted 14 years 3 months ago #44080David
- adamelphick
Posted 14 years 3 months ago #44143Please Log in or Create an account to join the conversation.
