On the hunt for a TF160
Does anyone on here have one for sale preferably with a hardtop close to Northampton.
:woohoo:
Don't rush out and buy a hard top until you are absolutely sure you need one.
James
The car was in reasonable condition and went well on the test drive. It came with a fresh M.O.T and no advisories but.............
Once I got it home and onto my ramp I noticed a bent rear trailing arm where it had probably been jacked up at some point.
First job was to replace the old and mixed make tyres with a new set of Toyo Proxes. Whilst at the tyre fitters they noticed a damaged rear wheel stud so that was added to the to do list.
The cam belts were 5 years old so changing those were the next job as well as a full service including new plugs and fitting a Pipercross panel filter. Nothing was straightforward and several seized bolts caused no end of issues culminating in new engine mountings, I also had "Torque tamer" bushes done. At the same time we replaced the damaged wheel stud which entailed removing the rear hub so that also meant a new wheel bearing. A new rear trailing arm was fitted at the same time.
Next was the exhaust, a new stainless system was ordered but on inspection it also required a new cat and lambda sensor, once these were fitted it was ready for Kmaps to do their magic and this was completed with a home visit.
Following the suspension work I took it for 4 wheel alignment, the "before"" readings were mostly red apart from the corner with the new trailing arm. The "after" is now all green, perfect!
This afternoon I'm going to fit a brake servo brace kit and then take it for a good test drive.
Next jobs are to install Xpower MK.1 roll hoops, fit Mintex M1144 racing pads, and get the drivers seat repaired:
Well that was an over optimistic statement.The brace kit didn't fit because my pre-production TF was fitted with an MGF heater intake box and the kit I bought was for the snorkel type intake only. Fortunately MG Mania were understanding and the return and refund was straightforward. The moral of the tale is read the advert!
So a bit more research led me to ordering a Mike Satur brace which was suitable for my set up.The vague instructions made the job appear to be simple but it proved to be an altogether more complex fitment which required some drilling and two pairs of hands for the installation. Anyhow job now done.
MG must have been using up their stock of F heater boxes I thought all TF,s had the snorkel. Would have been a good opportunity to replace the box for the snorkel though as they can be a source of water leaking into the cabin.
Keymaster wrote: Welcome aboard Seamus,
My car was the 3rd TF built (November 2001) and the VIN number is in the MGF sequence rather than TF so it isn't such a great surprise that it has the earlier box, it may even have some other crossover parts.
The Satur bracket looks to be a stronger and better finished solution than the MG Mania item and as far as changing to the snorkel there is no evidence of the MGF box leaking so "if it aint broke don't fix it".
