Newbie from Cheshire
i'm new here and to the MG. I have a 2001 1.8 MGF. It's done about 77,000 miles and isn't in bad condition at all, especially for the price. The all important head gasket has been done which is a plus. It runs pretty well except for the idle, i've cleaned the stepper motor and reset it but it's not solved it so going to try a new one. Apart from that it's all good.
So hello from me,
What is your idle doing?
James
- Away
The idle is reving up to about 1600 then dropping below 600, sometimes to the point of stalling. It only does it when you come off the throttle, i.e coming up to a junction. If it catch it before it drops too far then sometimes it will level out to a normal idle after a few seconds. Bit of a pain and left foot braking while tickling the throttle is getting a bit tedious.
First thing to do is a throttle body reset. If that doesn't work there are other things to look at.Jonny69 wrote: Thanks for the warm welcome
The idle is reving up to about 1600 then dropping below 600, sometimes to the point of stalling. It only does it when you come off the throttle, i.e coming up to a junction. If it catch it before it drops too far then sometimes it will level out to a normal idle after a few seconds........
