Newbie from Cheshire
Newbie from Cheshire was created by Jonny69
Posted 3 years 10 months ago #194945
Hi all,
i'm new here and to the MG. I have a 2001 1.8 MGF. It's done about 77,000 miles and isn't in bad condition at all, especially for the price. The all important head gasket has been done which is a plus. It runs pretty well except for the idle, i've cleaned the stepper motor and reset it but it's not solved it so going to try a new one. Apart from that it's all good.
So hello from me,
by Jonny69
Replied by talkingcars on topic Newbie from Cheshire
Posted 3 years 10 months ago #194947
Hi and welcome to the forum
What is your idle doing?
James
The following user(s) said Thank You: Jonny69
Replied by David Aiketgate on topic Newbie from Cheshire
Posted 3 years 10 months ago #194950
:welcome2:
Replied by Postman87 on topic Newbie from Cheshire
Posted 3 years 10 months ago #194951
:welcome:
Replied by Raccoon on topic Newbie from Cheshire
Posted 3 years 10 months ago #194954
Hi Jon, welcome aboard!
by Raccoon
Replied by Jonny69 on topic Newbie from Cheshire
Posted 3 years 10 months ago #194963
Thanks for the warm welcome :)
The idle is reving up to about 1600 then dropping below 600, sometimes to the point of stalling. It only does it when you come off the throttle, i.e coming up to a junction. If it catch it before it drops too far then sometimes it will level out to a normal idle after a few seconds. Bit of a pain and left foot braking while tickling the throttle is getting a bit tedious.
by Jonny69
Replied by Cobber on topic Newbie from Cheshire
Posted 3 years 10 months ago #194964
That sounds like the throttle body is sticking, a lot of our cars came with a 48mm plastic throttle body, better to bin it and put on a 52mm alloy throttle body (alloy 48mm throttle bodies are also available) the bigger throttle body is an improvment in drivability
Last Edit:3 years 10 months ago by Cobber
Last edit: 3 years 10 months ago by Cobber.
Posted 3 years 10 months ago #194965
thanks Cobber, i shall have a look at that
by Jonny69
Replied by Bob on topic Newbie from Cheshire
Posted 3 years 10 months ago #194975
Hello and
by Bob
Posted 3 years 10 months ago #194976
Thanks Bob
by Jonny69
Posted 3 years 10 months ago #194993
Jonny69 wrote: Thanks for the warm welcome :)
The idle is reving up to about 1600 then dropping below 600, sometimes to the point of stalling. It only does it when you come off the throttle, i.e coming up to a junction. If it catch it before it drops too far then sometimes it will level out to a normal idle after a few seconds........
First thing to do is a throttle body reset. If that doesn't work there are other things to look at.
Posted 3 years 10 months ago #194999
I've tried the reset but no difference. I've a new stepper motor on it's way so i will put that on and see if that cures it, fingers crossed
by Jonny69
Time to create page: 0.615 seconds
