yellow
yellow was created by shambo
Posted 5 years 4 months ago #195164
Hi, I'm James from South Wales, Have owned various F's and TF's over the years but mainly here for some help/suggestions while using TF donor parts to build a Metro.
by shambo
Replied by talkingcars on topic yellow
Posted 5 years 4 months ago #195167
Hi and welcome to the forum James
Which Metro do you have?
What MGF/TF parts do you have?
What are you hoping to achieve?
From another James
The following user(s) said Thank You: shambo
Replied by shambo on topic yellow
Posted 5 years 4 months ago #195168
TF is a 2004 135 with a good engine and gearbox (will be for sale once my 30 day / post target is reached)
Metro is a 1988 3 door Mk2 1.3, using the TF front and rear subs in the same configuration to put a V6 in the back.
by shambo
Posted 5 years 4 months ago #195170
Which V6 are you using?
If it is a KV6 you will be able to use the gearbox mounted digital speed sender to run the TF speedo in the metro and then use the digital signal from this for the TF EPAS.
Posted 5 years 4 months ago #195173
Unfortunately it's not going to be that easy, as much as I love the KV6 it just hasn't got what I want from a mid engined car, nor the capability for the power level I'm aiming for :(
I'm using a ford ST220 V6 and probably an Audi gearbox to start with, converting to a sequential 6 speed dog box when I can afford turbos.
by shambo
Replied by David Aiketgate on topic yellow
Posted 5 years 4 months ago #195202
:welcome2:
Time to create page: 0.452 seconds
