Switch Panel 1996 MGF Mk1
Hi,
My switch panel, where AC, power windows, defroster, AC is located, is broken. It is for a MK1 MGF.
I have not found one on eBay, Moss, etc. Anyone has one left or an idea where to get it?
thanks in advance and greeting from Germany,
Olaf
Olaf
by roggeo
To clarify, it's the 3 switch panel that you require? as opposed to the 5 switch panel?
I might have a spare 3 switch panel lying about, you can have it for nothing but the cost of postage, f you're desperate. but see if you can find one closer as the postage from. Australia might be a bit too costly.
Let me know if you want it, and I'll go digging for it amongst my spares stash.
MGFnTFBITZ in Glossop, they are bound to have what you want.
If it is a standard Mk1 f it will be designed to fit the larger buttoned switches for rear fog guard lamps, supplementary lights & rear window heater, the window control switches are the same across the range.
Having just reread your post I note that you require the A/C version, which has the five buttons & window switches. The Mk2 / tf panels are easier to come by, I would still recommend ‘Bitz. If they fail you, panels do crop up on eBay & so i recommend you check on a regular basis.
Last Edit:4 months 1 week ago
by Airportable
Last edit: 4 months 1 week ago by Airportable. Reason: Second thoughts
Hi Olaf,
The part number is FJM100650PMA and it appears that B&G have stock:
Panel-switches mounting Black Air conditioning - Brown and Gammons
Good luck
Mark
Good luck
Mark
[size=10pt]Mark[/size]
95 MGF
by mowog73
Last edit: 4 months 1 week ago by mowog73.
Time to create page: 0.370 seconds
