VVC head with Cams and timing pullies
VVC head with Cams and timing pullies was created by Seal
Posted 12 years 1 month ago #73812
If anyone has a VVC head the e3cam shafts and timing pullies, I am in the market.
Must be in a servicable state.
Many thanks.
by Seal
Replied by Luckymarine on topic Re: VVC head with Cams and timing pullies
Posted 12 years 1 month ago #73871
As a replacement for a damaged head?
Replied by Seal on topic Re: VVC head with Cams and timing pullies
Posted 12 years 1 month ago #73888
The head is ok and in good condition. When the engine was rebuilt the guy fail to fit the pulley correctly and the bolt hole become elongated and fractured the both that holds the pulley to the end of the camshaft. So it is probably better to get the three cam shaft rather that just replace the exhaust camshaft and pulley,
by Seal
Replied by Diesel Destroyer on topic Re: VVC head with Cams and timing pullies
Posted 12 years 1 month ago #73972
I have the 3 cams and pulleys if you want them
I no longer need them as my VVC head as been ported nd polished and converted to non VVC
The following user(s) said Thank You: Seal
Posted 12 years 1 month ago #73976
Many thanks for the offer, what price do you want for them?
And where are you located?
Many thanks.
by Seal
Posted 12 years 1 month ago #73995
I think it might be cheaper to just get a replacement exhaust camshaft and associated pulleys, VVC camshafts go for an arm and a leg each.
The exhaust camshaft shares its profile with quite a few models you might find in a scrapyard.
From direct experience if the VVC mechs are timed up properly and it works then leave well alone, nearly went mad trying to put mine back together, I could have done with 2 spare hands and an extra pair of eyes to get everything in place at the same time.
Your decision, it would be a good experience to tinker with the VVC unit if you want to.
Replied by David Aiketgate on topic Re: VVC head with Cams and timing pullies
Posted 12 years 1 month ago #74015
Seal wrote: Many thanks for the offer, what price do you want for them?
Many thanks.
Click on location under the avatar.
You need to set yours though, you're in Ohio!:lol:
Glovebox at the top, on left 'set your location'
Posted 12 years 1 month ago #74155
David,
May be that I am missing something but am unable to get any response when following your insturctions to change my location?
Many thanks.
Last Edit:12 years 1 month ago by Seal
Last edit: 12 years 1 month ago by David Aiketgate.
Posted 12 years 1 month ago #74242
Are you getting the map when you click on set your location?
Last Edit:12 years 1 month ago by David Aiketgate
Replied by Leigh Ping on topic Re: VVC head with Cams and timing pullies
Posted 12 years 1 month ago #74325
You could try going to members map under the community tab above and then drag and drop the little man to where you are in the world. :)
Last Edit:12 years 1 month ago by Leigh Ping
Last edit: 12 years 1 month ago by Leigh Ping.
Posted 12 years 1 month ago #74330
Many thanks.
£55 posted
2 xVVC cams shafts
1 x Exhaust cam
4 x pullies
All from standard TF 160 engine
Allan
I'm in Swindon, Wiltshire
Posted 12 years 1 month ago #74334
Time to create page: 1.498 seconds
