**URGENT** WHEEL... ANY DESCRIPTION!! Spare etc...
**URGENT** WHEEL... ANY DESCRIPTION!! Spare etc... was created by benham
Posted 11 years 8 months ago #105282
Hi all,
As my car has slipped off it's jack and got wedged up against my garage wall I urgently need to buy/borrow ANY wheel that'll fit an MGF, spare, knackered, steel, bald/illegal tyre, doesn't matter, it's only to move the the car a few feet......
I'm located in Bedfordshire, of course if somebody can lend me a spare for half a day they will be rewarded with a few beer tokens!
Regards,
Andy
by benham
Replied by mandymay1971 on topic **URGENT** WHEEL... ANY DESCRIPTION!! Spare etc...
Posted 11 years 8 months ago #105283
I have four spare Andy but alas we may be a little to far away in Leicestershire
Replied by quick_spider on topic **URGENT** WHEEL... ANY DESCRIPTION!! Spare etc...
Posted 11 years 8 months ago #105284
I can lend you one I bought off you - could pop up tomorrow morning whilst the wife is at work if that helps?
The following user(s) said Thank You: benham
Replied by benham on topic **URGENT** WHEEL... ANY DESCRIPTION!! Spare etc...
Posted 11 years 8 months ago #105286
That'd be immeasurably bloody kind Quick-Spider!
Typical eh? Lol
Regards,
Andy
by benham
Posted 11 years 8 months ago #105287
Now I've got the emergency reassembly of both sides of the rear of the car! :(
Better get cracking! Only got 6" of space on the OS of the car, also sustained a massive injury to the OSR sill and wing :(
Regards,
Andy
by benham
Replied by mogatrons on topic **URGENT** WHEEL... ANY DESCRIPTION!! Spare etc...
Posted 11 years 8 months ago #105289
That's really crap news Andy .. :( .... but could've been much worse if you'd been working under it at the time ...
At least you've still got all your limbs intact to carry out the repairs. ;)
Replied by David Aiketgate on topic **URGENT** WHEEL... ANY DESCRIPTION!! Spare etc...
Posted 11 years 8 months ago #105290
I hate working under the car for that very reason and my drive is all slopes, there is no flat area.:nonod:
When I was doing the hydragas/suplex change, I had the front off the ground on two axle stands, but needed the back raised too.
So I put the trolley jack under the back centre lift point and raised it preparatory to putting two more axle stands under the back. I turned away to pick up the axle stands, turned back to see the car slide sideways off the jack and overturn the two front axle stands.
That was very sobering! :pinch:
Also good fun trying to lift the car on a scissor jack to try to extract the trolley jack and axle stands... :whistle:
Last Edit:11 years 8 months ago by David Aiketgate
Last edit: 11 years 8 months ago by David Aiketgate.
Posted 11 years 8 months ago #105298
Thanks for the kind words guys....
.... Also my nicely organised pile of nuts and bolts for the entire rear of the vehicle has been upset, so gone to start putting the back end together and no bloody idea what goes where :(
Very true though, at least I wasn't under it.....
.... and of course, what was I doing?
This is the space I've got left to work in :(
Plus side, tons of room on the near-side!
Regards,
Andy
by benham
Posted 11 years 8 months ago #105318
Ideally you need to get a pair of dollys under there Andy, then you can position the car exactly as you need it.
Is there a local toolmart hire place nearby that you could lease them from?
Posted 11 years 8 months ago #105323
I can bring a low-lift jack too if that helps...
Posted 11 years 8 months ago #105329
quick_spider wrote: I can bring a low-lift jack too if that helps...
All sorted cheers buddy, a MASSIVE thank you to Ocado Man (John) who banged on my door a little while a go with a spare wheel to borrow, so generous, and I will be forever in his debt!
The car is back upright again, sans a fair chunk of its OSR sill, (it was clearly rotten, I just tore it all off with my hands) so I will be needing to dig the welder out in due course methinks!
I realised it was getting dark and futile to chase a load of nuts and bolts around the garage floor, so I thought I'd quickly fit the exhaust manifold I've recently bought in preparation for shunting the car in and out of the garage (I'd removed and scraped the factory one). I've also refitted the sump after fitting the sump baffles supplied by Quick-Spider, filled with oil, and just turned the engine over....
Suddenly noticed massive oil slick approaching me....
..... Who forgot to put the sump plug back in?! :bang:
...Shut garage door, not touching anything else today!
We have some dollies at work I may borrow for final "shunting" though, we used them for moving GRP kiosks around, so hopefully they'll work with a MGF!
Mogatrons, do you have some Mogadons I can borrow?! ;)
Regards,
Andy
by benham
Posted 11 years 8 months ago #105335
Strategic withdrawal, I think. :yesnod:
