wanted
wanted was created by graham1
Posted 9 years 5 months ago #175290
has anyone got a rear splash guard for a mgtf, thanks. :-? and any drop links rear thanking you kindly
Last Edit:9 years 5 months ago by graham1
Last edit: 9 years 5 months ago by graham1. Reason: forgot to add drop links
Replied by graham1 on topic wanted
Posted 9 years 5 months ago #175309
by graham1
Replied by Leigh Ping on topic wanted
Posted 9 years 5 months ago #175310
graham1 wrote: ????????????????????????????????
Click the words. They contain a link. :dry:
Posted 9 years 5 months ago #175311
yes but not paying 20 odd pounds for a bit of plastic thought I could get a cheap second hand one on here. :bang:
by graham1
Replied by Andy Lawrence on topic wanted
Posted 9 years 5 months ago #175313
I don't think £25 is bad for one as it's quite a very important part.
Not only is it a splash guard protecting the expensive alternator but also a stone guard.
You see, events could follow this pattern.
1, stones get flicked up into auxiliary belt.
2, auxiliary belt fails.
3, failed auxiliary belt gets into bottom pulley.
4, said auxiliary belt takes out the cambelt.
5, catastrophic engine failure occurres.
6, you either walk away and scrap the car losing all you've put into it or find a replacement unknown engine.
All for the sake of a £25 part.
It has happened.
WHALE OIL BEEF HOOKED
Replied by David Aiketgate on topic wanted
Posted 9 years 5 months ago #175315
Make one. I did. :yesnod: You just need a large plastic container, to give you a flat piece of plastic big enough to cover the gap between the subframe and the top of the inner wheel arch.
Easy and free!
I have one on both sides of the car, just because I could...
Last Edit:9 years 5 months ago by David Aiketgate
Last edit: 9 years 5 months ago by David Aiketgate.
Replied by richandpaula on topic wanted
Posted 9 years 5 months ago #175318
If you can't find one and decide £25 isn't a bad price, then there's this one: http://www.johnwoodsmotorcare.co.uk/Shop/index.php?main_page=product_info&cPath=53_57&products_id=395
Replied by helsbyman on topic wanted
Posted 9 years 5 months ago #175319
richandpaula wrote: If you can't find one and decide £25 isn't a bad price, then there's this one: http://www.johnwoodsmotorcare.co.uk/Shop/index.php?main_page=product_info&cPath=53_57&products_id=395
Your still alive then
Long time no see, John
Posted 9 years 5 months ago #175321
Hi John, Yep, still alive & well and enjoying the MG's - Saw the guys from John Woods & Simon the other day. :drive:
Replied by COMMANDER on topic wanted
Posted 9 years 5 months ago #175367
Having read Tyre Man's post above I checked to see if my TF has one fitted. Nope, just one broken scrivet. I love that word. New one ordered, with scrivets.
The following user(s) said Thank You: Leigh Ping, Andy Lawrence
Time to create page: 2.264 seconds
