Needed - Nylon retainer for gear lever mechanism
Needed - Nylon retainer for gear lever mechanism was created by winston06
Posted 8 years 5 months ago #183192
I have tried my usual sources but they were unable to assist so I am hoping spomeone out there can help.
I have an MG TF 03' Plate and the gear cable adjuster at the bottom of the gear shift recently broke.I managed to source a replacement (without the need for a whole cable courtesy of (mgandamcparts.com).
Once completed I wasn't able to change into 1, 2, 5 & reverse and notice the retainer (Nylon?) was sliding in and out of the square Nylon housing which slots into the shift mechanism.
I cannot find this item anywhere and it has rendered my car inoperable.
Can anyone offer my any advice on where to source this from new? Or a scrap part of an old mechanism laying around?
Your help would be greatly appreciated.
Last Edit:8 years 5 months ago by winston06
Last edit: 8 years 5 months ago by David Aiketgate. Reason: Insert photos
Replied by David Aiketgate on topic Needed - Nylon retainer for gear lever mechanism
Posted 8 years 5 months ago #183200
Only going from memory, but that doesn't look right at all. Are you sure you've put it back together correctly?
I may be able to get a photo of my gear lever assembly tomorrow to compare.
Replied by talkingcars on topic Needed - Nylon retainer for gear lever mechanism
Posted 8 years 5 months ago #183204
A quick surf found this -
Replied by g4wam on topic Needed - Nylon retainer for gear lever mechanism
Posted 8 years 5 months ago #183209
Hi there -I also think you have made an error with the mounting-have enclosed a picture of a working unit before fitment
Mike
Last Edit:8 years 5 months ago by g4wam
Posted 8 years 5 months ago #183240
talkingcars wrote: A quick surf found this -
Yes, thanks James & Mike, that's how it should go together! Saved me dismantling mine!
Last Edit:8 years 5 months ago by David Aiketgate
Time to create page: 2.002 seconds
