Re:MGF rear hydragas unit needed in USA
Does anyone have any usable MGF rear hydragas spheres for sale and would be willing to post to the USA? Have one here that is leaking fluid. Understand that Metro front may be the same? I do have the tool to charge/discharge the system.
Just need to get car raised enough to be moveable. Long term will probably go with Mike Satur retrofit kit or refurbished spheres.
Thanks, Brad
Thanks, Brad
by verofan
Replied by talkingcars on topic MGF rear hydragas unit needed in USA
Posted 4 years 11 months ago #196590
Hi Brad
For the hassle and expense involved I would consider getting some refurbished spheres from the get go, and the ones with added nitrogen valves are the most future prove ones.
Metro spheres do fit but are softer than the MGF ones, metro owners beef up their suspension by fitting MGF spheres.
The Mike Satur kit, and alternatives completely change the way the car drives so it is no longer a MGF, more like a MX5 which was basically a MGB but that's another story.
James
James
by talkingcars
The following user(s) said Thank You: verofan
Replied by verofan on topic MGF rear hydragas unit needed in USA
Posted 4 years 11 months ago #196596
Hi James,
Yes, I see your point about the refurbished units. However, Rimmer seem to be out of stock right now. There is also the issue of cores which may simply not be worth shipping back to the UK, at least not in small quantities. Unfortunately USPS discontinued surface mail some years ago.
Thus, I am looking for a stop gap solution.
by verofan
Replied by Cobber on topic MGF rear hydragas unit needed in USA
Posted 4 years 11 months ago #196597
Rears are always the first to go, my guess is that they carry a little more weight and as they are in the engine bay they're exposed to more heat.
So rears are always in more demand and harder to find.
As far as I can only see the difference between front and rear units is the alloy socket at the bottom. They are different lengths.
this can be swapped over, the trick (to do this the unit must be removed from the car) is to apply air pressure to the fluid port, fully expanding the lower diaphragm the cone shaped alloy socket can now be removed (it just sort of tucks into a lip in the diaphragm) and the replacement tucked in.
So if you can get your hands on a front unit, you could "convert" it into a rear unit.
I understand that the Trophy models used the same part # units front and rear, these are almost impossible to get now. For those with a MGF Trophy they could perhaps, fit the cone shaped sockets from the Trophy units to the standard model front units.
Last Edit:4 years 11 months ago
Last edit: 4 years 11 months ago by Cobber.
Replied by David Aiketgate on topic MGF rear hydragas unit needed in USA
Posted 4 years 11 months ago #196603David
by David Aiketgate
Last edit: 4 years 11 months ago by David Aiketgate.
Replied by Steve on topic Re:MGF rear hydragas unit needed in USA
Posted 4 years 11 months ago #196638
https://www.hydragasandhydrolasticservice.com/hydragas-service/
These guys replaced mine, they will post anywhere.
by Steve
Last edit: 4 years 11 months ago by talkingcars.
Time to create page: 0.436 seconds
