Alloy Door Pins - How to fit.
  • SamLuck
  • Journeyman MGer
  • Journeyman MGer
  • Blue Belle
Alloy Door Pins - How to fit. was created by SamLuck
Posted 16 years 8 months ago #1006
Added my next bit of bling today! They took 1 hour and 20 minutes to fit because my Dad and I encountered some difficulties!
Thanks to Kara for the 'How To' on how to remove the door cards It was dead easy!
Remove the two screws in the coin holder:
[img
[img
Then one screw behind the handle:
[img
[img
Open the door wide and undo the screw on the inner edge:
[img
[img
Then finally the two screws on the outer edge of the door:
[img
[img
Gently take the door card off:
[img
[img
The existing door pin:
[img
[img
This was the easy bit! Then Dad was called.
Cut the existing door pin off, as it is moulded on:
[img
[img
No way was I going to risk cutting myself!
Then your left with the bare rod:
[img
[img
It was all going well up till now when we had to fit the new alloy pins!
The diameter of the pins was not large enough to fit round the existing door rod. Dad didn't have the correct drill bit to drill inside the new alloy pin, so we had to file the rod down:
[img
[img
Eventually both the new pins fitted and then we had the job of putting the door cards back on!
[img
[img
[img
[img
Last Edit:15 years 8 months ago by SamLuck
Last edit: 15 years 8 months ago by David Aiketgate.
Replied by Blow-in on topic Re: Alloy Door Pins - How to fit.
Posted 13 years 10 months ago #63951
Done this job now thanks. Found the hardest bit was cutting off the old black plastic pin....in the end I hack sawed down until I found the rod and removed the plastic top end then I used a dremel style tool with a cutting disk to make 3 vertical cuts in the rest of the plastic which then peeled off like a banana skin. Best to do this job with the window down. I then put some black tape around the rod to give my universal (£3.20) allow pins a bit more grip...the pins go on after the card is refitted as they are bigger than the hole (one reason not to superglue them in case you need to remove the trim again).
Richard
by Blow-in
Time to create page: 0.373 seconds
