Windows
Hi Wooddy,
Is your car an F or a TF?
Hi dave it's a tf everything worked just fine when I got it but I have just got a hardtop for it the heated rear window worked ones then blow a fuse I replaced that but the light doesn't light up anymore could that have anything to do with the windows not working
Last Edit:13 years 7 months ago
by Wooddy
Last edit: 13 years 7 months ago by Wooddy.
Hi wooddy, for both the motors on the window winders or both the switchers to go at the same time is a bit odd and that only leaves the fuse or a bad connection at some where like the fuse box as both windows don't work
by helsbyman
As they've both stopped at the same time, and you've checked the fuses, it is probably the window control unit/relay which is within the Body Control unit.
I would test the motors independently, before starting on that path, though!
