Removing and replacing headlights - MG F
Originally I'd hoped to be able to have my dim lights resilvered on my MG F but in the end the carcasses weren't that good so I resorted to new fittings - either way you still need to remove and replace the lights like this.
First, remove the bumper - see http://www.the-t-bar.com/en/forum/54-how-tos/87328-removing-the-front-bumper-on-the-mg-f
Each headlight is secured (or not in my case) by 2 top fasteners accessible under the bonnet, a side fastener through a lug on the wing and finally a lug on the bottom of the light that goes in to a chassis grommet (assuming it's still there - I had one missing).
So unplug the wiring:
Remove the 2 top fasteners - these are replacements in stainless steel so no bother
Then have a cup of tea before tackling the machine screw in the side web
The chances are this will be corroded solid so if you force it the web will break off - if you are planning to re-use your lights you will want to avoid this of course so grind or cut off the head - you will then need to clean-up the fixing so that you can use a M5 nut & bolt as a replacement.
Lastly there is a lug under the light that goes in to an oblong hole with grommet - just ease the top of the lamp forward with a wiggle or 2 and is should be out....
I started with one broken side web, broke the other one, had a dodgy seal on one lamp and a few other issues so I did the sums and decided to go for new units (see: http://www.the-t-bar.com/en/forum/9-mgf-tf-pitstop/87314-mg-f-headlights-a-recommended-supplier)
As they say refitting is the reverse of removing...but there are a few tricks.
I used stainless steel on all the fittings so hopefully the side webs won't be such an issue next time but in any case...
I covered this new fitting in vaseline to keep some of the air off it. I then taped over it too to try to keep the crud off (it can still drain)
I started off the refit by plugging-in the wiring
When you refit the lights new units will be a bit tight because the external rubber seal will be un-compressed. It requires some jiggling. I located the tab first in the grommet then twisted the light in so that the seal was behind the wing (on the left wing it was so tight I had to loosen the wing slightly at the top first)
I then loosely put in the top fasteners then the side web fastener..
Then I tightened-up the fittings
Having checked that it was all working I replaced the bumper and then took the car to our local test centre who aimed the lights for me for a £5 contribution to the tea fund (top bloke Arthur MacArthur).
I can finally now see where I'm going in the dark...pity you can't replace the Mk1 eyeball so easily!
Richard
Attachment wiringplug.JPG not found
Attachment topfixings.JPG not found
Attachment sideweb.JPG not found
Attachment Lowerlug.JPG not found
Attachment newwebfitting.JPG not found
Attachment tapingoveropenweb.JPG not found
Attachment Newweb.JPG not found
Richard
Last Edit:13 years 6 months ago
by Blow-in
Last edit: 13 years 6 months ago by Blow-in. Reason: pictures missing
Replied by bensewell on topic Removing and replacing headlights - MG F
Posted 13 years 6 months ago #98222
Well done thanks for sharing :]
by bensewell
Replied by David Aiketgate on topic Removing and replacing headlights - MG F
Posted 13 years 6 months ago #98229
Excellent!
Replied by Bob on topic Removing and replacing headlights - MG F
Posted 13 years 6 months ago #98392
Great how to and the m5 nut tip is very useful. I could have used this how to when I did my lights.
I might pop my bumper off and change the rusty lower bolts now I know the size
by Bob
Last edit: 13 years 6 months ago by Bob.
Time to create page: 0.604 seconds
